Calu-M2C Power on question
  • Calu-M2C Power on question
    Hey Guys,
    Had this baby installed a meelion years ago, but then car went through some changes and now im finally installing it again.
    I connected it as follows:
    Red: constant power
    white: negative / ground
    Green: ignition switch (ie: gets 12v when i turn key to "1")
    However, the computer isnt switching on upon turning my key or even switching on my car. Is the above wiring incorrect? I didnt change the bios settings or anything like that, so should all be the same and it used to work way back when ?
    TIA!
    After further investigation, I see that it doesnt power on upon ignition when i have my CTF700 screen's usb port attached - but with it disconnected, it works - what gives?
      have you tried connecting the screen to another pc?
      next project? subaru brz
      carpc undecided
        Hmm, will have to organise a laptop to check it out :S will revert back once i know what happens...
          So I got a laptop and the CTF700-SH does the exact same thing to my laptop, (though a bit different - power goes on, but the screen stays black and so doesnt go through post or anything). Works fine if I unplug the USB port of the CTF700 - but with it in, bam - no go!
          What gives?!? TIA!
            sounds like a bad touch overlay, or touch controller. you'll either need to replace both, or replace the screen..
            carpc undecided
              Damn!
              How do I go about checking which of thw two it is and how do I replace the two?
                i'm not really sure.. try checking the lcd section.
                carpc undecided
                  Just for future reference, for anyone who has this issue - for me, it was because of a fault USB extension cable connecting the touch panel.
