CarPc for Dodge Charger Help
  • CarPc for Dodge Charger Help
    I'm a newbie to carpc but not to the pc world ..... i want to put a carputer setup in my wife's charger along with a full system 2x 10' kicker's mids/highs 2x amps but i just installed the eclipse navigation is it possible to keep the eclipse navigation as a monitor by using the video input (ex: as hooking it like a playstation in car) and use a keyboard and mouse to run the carputer cause i will assume that the eclipse will not be able to run the carputer using the touchscreen
    Yes, you could send the audio through the headunit. The windows desktop & front end should show up on the screen through a video input but you are correct, no touch screen. I don;t know what size you will use to get the desktop to fit properly so you will have to experiment with that unless someone else chimes in that has done this.
      you just need a vga to composite signal converter. it is discussed a little in this thread:
      next project? subaru brz
      carpc undecided
