s10 car pc install* tips needed*
  • s10 car pc install* tips needed*
    hey guys i been reading for a few weeks now, and there is too much info to take!, i mean i have learned alot! but i just need some guidance as to what should i do. ok here is the pc im messing with, got it for free cant complain, and it was complete! also note that i do have a second battery in my truck, if this even matters.
    dell 4400 Specs: better yet heres the link:
    http://support.dell.com/support/edoc...4400/specs.htm
    now my plan is to basically run xm, gps, and basically control what i can, it might be kind of crazy, but im gonna run a 15in monitor with a touch panel kit!
    now my questions is:
    recommended power supply?
    recommendation for heat, as in im not running an ac( got a mini truck) and im in texas!!?
    like any links to stuff like power supplies, or gps units, xm units, powermates, or anything i missed or you guy recommend, becasue there is alot of stuff and im like overflowed by it. and i just need like a first step to start. so anything you guys think i should look into, just let me know. and yes i have been reading, but im a person that kindof needs like a one on one advise, thanks yall
    the laptop section is going ot have the most amount of relative info.. specifically, anything to do with Dell laptops. they sometimes have a funky power connection that needs to get hacked.. i would recommend focusing first on powering it, and then moving onto connecting the devices..
    next project? subaru brz
    carpc undecided
      no no sorry,its not a laptop. i put the link it takes me to a bs page from mp3, but the desktop is a dell inspi-whatever 4400.
      i know you where going to respond lol. but let me know what you think i should run to power it than we move on to other things you recommend for me, thanks soundman!!!
        *after PM response*
        yeah, that is definitely not a laptop... i believe i have one of those at home with a bad hard drive...
        still, look into powering it first, i highly recommend dc-dc, or 'intelligent' automotive atx power supplys-- and then move onto each device-- specifically, search for a power calculator to make sure that you get a power supply that is big enough to support the pc components.
        carpc undecided
          *after PM response*
          oh ok, yea i tried to use the calculator but i cant seem to find the specs of my intel. i have no idea what im looking for and there is 100s of them on the site. lol
            any recomendations to power this thing with accesories also?
              can someone please tell me about which dc power adapter i need? thanks
                The Inspiron 4400 you linked uses a 250w power supply that plugs to a standard 110 outlet. In a car, a theoretically perfect replacement would be the M4 Intelligent ATX DC-DC PSU. This should provide the same power in your car that the standard power supply gives you at home. If you need more than that for peripherals/screen, you may want to get a separate supply. Specifically for the screen, I'm thinking. The M4 should be able to handle your tower and various bits, but since a screen isn't normally powered from the tower's PSU, it may be safest to power that one with another dc-dc supply. Do you have specs on the screen itself?
                  i don't know if it is the moderation que, or i'm just flaky,(probably both ) but i keep missing this thread...
                  i recommend against the m4, or the m-series in general-- just search for mickz's posts in the thread about reducing radio interferance...
                  i currently use a dsatx, and would also recommend anything in the Opus, or Carnetix lineup's. all three of these, like anything still have the occasional problem, but nowhere near the problems that any of the m-series power supplies have--just look at the amount of threads about each device...
                  carpc undecided
                    its a dell 15in flat panel witha touch screen panel kit. i forgot the model number
                      I was under the impression the M-line was good. My apologies.
                        ^it is cheap-- which makes it popular.. i should rephrase my response a little-- it seems that while there are many m-series power supply users that hare happy/satisfied with their psu, it seems there are at least just as many that have problems with those exact same models...
                        while i understand that there are always problems with electronic devices-- either due to manufacturing tolerances of components, overall installation location, user error, or general life-expectancy of the device, it seems that the m-series is much more prone to problems-- more-so then any other brand/model of power supply.. this is easily evident in the amount, and length of threads in the power supply section..
                        though, the amount of problems could be due to the popularity-- ie. if the dsatx was more popular, would there be just as many threads about it? i really don't think so, but am open to discussing it more!
                        at this point, i feel like the m-series is similar to rolling the dice.. you might get lucky and have zero problems, but you might also be one of the unfortunate...
                        while i do enjoy tinkering with my carpc, i prefer to do it on my schedule, not the psu's...
                        carpc undecided
                          ok soundman, so far i got my psu, touch screen kit, and 2 more fans, now as for my project attack. ok im gonna use the hard drive thats there already, it has windows xp for now, but i did strip the case to bear minimum. im also putting a 5.1 sound card to run my speakers along with amps. i do have 2 batteries in my truck so i dont think i will have a problem at all for power issues. anything else you think i should look at?
                          i got 2 psu the dastx and a m4(free) just to try them out, got the sound card, screen kit, fans, and im making my own box for it out of aluminum.
                            I recommend, if you have the room, ditch the machines case and attach the PSU, mobo, and hard drive securely to a piece of MDF and place it under the seat center of the vehicle. You can use an inverter also, some may argue but if you ground it right you will not have any problems that may be associated to an inverter.
                              ^ i thought it the noisy inverter installs were noisy because of the way that the inverter was built, not a grounding issue?
                              though it is easier just to stay away from overly complex (kinda ironic statement on this board, huh?) power setups involving inverters..
                              shadow-- it sounds like you have everything under control to me! (and if leo hadn't bumped the thread, i would have missed it again!)
                              carpc undecided
