Will a 240watt amp power....
  • Will a 240watt amp power....
    Just bought 2 Sony Explod 12" Subs for 50 quid brand new
    However they came with a 240watt Amp will this power them safely? Not expecting massive high end bass just enough bass to fill my van
    James
    Yes, it will power them safely.
    RevFE
    My Shop
      yes, they will work, just expect the subs to play a little 'loose'. ie: on a song like Ushers "Yeah", the subs will 'thwomp' more then they will 'bump'. this is because the lower amount of power has less force to control the subs movements.
      next project? subaru brz
      carpc undecided
        Will a 2000watt amp be too much or be perfect for them?
        James
          I think it will be much for these. I usually go with the power advised by the company. If 240 watt can do this ob nicely then 2000watt will be too much. Its my point and don't know whether others will agree with it or not. Let them suggest.
            Will this amp work better?
            http://cgi.ebay.co.uk/ROCKFORD-FOSGA...item3a65ac37ea
              Originally posted by james1905 View Post
              look at the specs:
              Originally posted by ebay link's manual
              RMS Continuous Power @ 14.4V (Competition Standard)
              Stereo into a 4Ω load (20Hz-20kHz, <0.05% THD) ............ 25x2
              Stereo into a 2Ω load (20Hz-20kHz, <0.10% THD) ............ 50x2
              Bridged into a 4Ω load (20Hz-20kHz, <0.10% THD) ........ 100x1
              it is slightly worse power-wise then the one you currently have.
              but always be careful with used electronics-- unless they are very cheap, or you have heard them working in person, don't buy..
              those subs box says they will take 350w rms. just look for a amp with a rms rating that matches that.
              carpc undecided
