Planning my first CarPC in my 2006 Altima SER
  • Planning my first CarPC in my 2006 Altima SER
    Hey, here's what I have planned out so far for the hardware of my first CarPC. The car is a 2006 Nissan Altima SER with the Stock 6-speaker Bose system. I am going to be replacing my JVC KD NX-5000 DVD Single DIN head unit with the Carputer. The stock Bose stereo consists of an Amp in trunk, w/6 speakers; 2 Component 5.25" up front with 2 5.25" in the rear doors, and 2 6x9's used for bass only in the rear deck, I have the adapter for the wiring harness that converts it to 2 RCA pair's for input from the head unit. Which will make it easy to connect to the Carputer.
    The current part list that I have made up is as follows: (Please note all recommendations/comments are appreciated!)
    Motherboard: ASUS E35M1-I DELUXE
    Specs: ASUS E35M1-I DELUXE Motherboard/CPU Combo:
    AMD E-350 APU (1.6GHz, Dual-Core) | AMD Hudson M1 | 1 x PCIe 2.0 x16 (at x4 mode, with latch) | 5 x SATA 6.0Gb/s | AMD Radeon HD 6310 graphics | Realtek ALC892 - 8 Channels | WiFi IEEE 802.11 n | Bluetooth 3.0 | PS/2: 1, DVI, 1 x HDMI, 4 x USB 2.0, 2 x USB 3.0, 1 x eSATA 6.0Gb/s, 1 x Optical, 3 Audio Ports, Mini ITX - 6.7" x 6.7"
    Features
    Integrated dual-core AMD E-350 APU 18W processor
    USB 3.0/SATA 6G- High Speed Transfer Technology
    EFI BIOS (EZ Mode)- Flexible & Easy BIOS Interface
    Wireless and Bluetooth on board
    RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
    HDD Boot: OCZ 30GB SSD SATA II 2.5"
    HDD Storage: Seagate 1TB SATA 3.5" (I have this already)
    Case: Looking into new options
    PSU: Mp3Car DSATX 220 Watt Automotive Power Supply
    LCD: Not sure yet, possibly the Samsung derrick.ny LCD
    GPS: BU-353 GPS USB Receiver
    OBD II: plx Devices Kiwi Bluetooth Adapter
    OS/Frontend: Windows 7 Ultimate / Centrafuse or RoadRunner (haven't decided which yet)
    All necessary cables, adapters, double din mounting kit, etc...
    I also put together a crappy basic wiring diagram for myself to use:
    That's everything, as soon as I start ordering parts and building it, I'll put up a worklog... can't wait to get this project started. If anyone has any helpful hints, tips or tricks, please share!
    Minus that, I've been searching and reading up on the forums to learn everything I can before I get waist deep into the project.
    Worklog: 2006 Nissan Altima SER CarTab!
    i really ought to give you a hard time about keeping the stock bose amp installed(esp. with a slogan like that!!)...
    you really don't need any more then 2gb ram in-car-- the more ram you have, the longer hibernate times you have, not to mention the extra cost and little use it would have.
    also, the m4 psu will not fit in any case, but you can order a external case for it..
    next project? subaru brz
    carpc undecided
      I agree with the above. M4 is kind of overkill for an Atom board, but the worst part is that it's big.
      Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
      Skin: MetroSex on the Beach preview
      07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
        if you think about it, this hobby is overkill...
        it depends on the way the system changes--i started similarly with a dsatx, and intel atom board, but the psu was a worthwhile expense when i upgraded to the different board a couple months later, and i didn't need to change the psu. but i also don't run a case, so space wasn't as much of a issue..
        carpc undecided
          Lol, I know I know, I don't even like the Bose system (or Bose at all actually, I've never heard a Bose speaker that I've really like) but its a ton of money and work to swap out the speakers and run all new wiring. Since I don't have any of the speakers or amps for the speakers from my last car. All I have is 2 10"s in a box w/an amp for the subs. So I have to get all new speakers and a 4-channel amp, then run the wiring through the car into the doors . Eventually I will end up getting speakers/amp(s) and getting rid of the Bose crap, just not at the moment.
          Quick question (as I'm new to this CarPC thing), why would the PC be going into hibernate? From my experience Windows + Hibernation is never a good idea . But thanks for the tip on just using 2GB instead of 4GB, I wasn't sure if 2 would be enough... that'll save on heat/power too!
          Ahh, I didn't even think to check the size of the M4, I just saw all the useful features and figured all these CarPC PSU's are small, guess not. I'll go check out what else is available that's smaller and will fit inside the case, thanks again!
          Thanks, I'll def. check out some other options, maybe an M2/3? I just want to make sure I get a PSU that has the SSC built into it, as well as any other useful features to keep my motherboard from dieing.
            I'm using the Carnetix P1900 for a board that's the same specs as your proposal (1 stick of RAM though). The features available on that seem more than adequate. I do believe thy are more efficient than the M-series. Size may be an issue here too, but it has its own metal casing and can simply be externally mounted.
            Welcome to the hobby! As a fellow newbie I can tell you that without this site, this wouldn't be the route I would take for my car.
            -Zack
            via Droid Charge
              Thanks for the replies guys, keep them comming!
              I am definitely going to be looking into a different case, since I have a 3.5" HDD for storage (for now to save $$) and from the look of it, won't be putting the PSU in the case with the HDD/SSD/MoBo... I'm going to check out NewEgg's Mini-ITX cases, and look into either an Opus or Carnetix PSU.
              Only issue I am worried about is my MoBo requires 20Pin ATX + P4-12V 4Pin, so whatever PSU I get must have both connections. I'm not too worried about the LCD as that will be in the front of the Vehicle, so I'll probably power it separately. Just need adequate power for the MoBo, HDD/SSD and USB devices that will be plugged in (GPS, and whatever else I may plug in up front in the hub, probably just MP3 Players/phones for music transfer/charging).
              Time to continue looking around at cases and Power Supply's, and I'll update my first post with the new parts.
                it doesn't need to, but many people setup their carpc to standby/hibernate when they get out of the car, so that when they get back in, they have faster startup times.
                i personally just let my pc startup/shutdown, and don't really feel a need for a super-fast bootup, but it's personal preference..
                in most cases, hardware/software should not be affected by using standby/hibernate(these days, almost all hardware can take it), but sometimes, if the software was poorly written, or a usb device suddenly decides to not show in the hardware list, it can cause issues with resuming..
                carpc undecided
                  IF you have a motherboard with a standard ATX conenction (20 or 24-pin), then you want an ATX PSU. A Carnetix unit is not ATX-compatible.
                  How about the Wiki?
                    you gotta quit skimming in the OP's last post, he indicates that he understands that the opus won't work, and is looking at other atx-compliant psu's
                    carpc undecided
                      Thanks for all the suggestions guys, I decided on going with a DSATX, that way I'll be ready if I ever want to upgrade in the future, and from reading through all the PSU's manuals that one has all the features I could ever imagine needing. Not worth skimping out on one of the most important parts
                      All I have left to do is figure out what I'm going to do for a case (buy one - would have to find one that I like/will fit everything with good cooling or build one - which would be smarter to fit my specific application but is tougher to do)
                        being that you are going with the dsatx, there are not any car cases that will work-- it is just too big.. but some home-theater-type mini-itx cases might work..
                        carpc undecided
                          Why not just have the power supply external? I'm thinking only theoretically here. Is it more complex than I assume?
                          -Zack
                          via Droid Charge
                            Okay, thank you for helping me narrow my search, I think I might have found a case, but just need to do some more measurements and stuff.
                            Also, after checking out some threads on the forums here, building a custom case isn't ruled out at all.
                            -Zack
                            via Droid Charge
                            I could do that, and it probably would be easier, but personally I like the look of everything being in one case. I wanna go for the sleeker look, plus to not have to run the cables between cases (ATX connector, etc) seems as it would be easier. Also, I am trying to keep this to as small a footprint as possible, just for storage/looks reasons. I know I have to be sure to have adequate cooling for the PSU/PC (I am a big PC modder, currently on a watercooled system, so I know the dynamics of that and will factor it into whatever case I go with).
                              Ah, good man, sticking to your standards like that. My aim is to keep the entire computer (except hard drive array) inside my dash. So I understand when you want to set yourself a standard and stick to it.
                              Another thing to keep in mind if a case is problematic for you to find: companies like Danger Den can build custom acrylic cases. So if you need a little more room for the PSU, consider having that done, as you can specify dimensions.
                              -Zack
                              via Droid Charge
