Car computer software with command line interface to trigger actuator
  • Car computer software with command line interface to trigger actuator
    Does anyone know of car computer software that has a command line interface that i can use to communicate with a circuit board that will trigger actuators to open doors/hood/trunk etc.
    For instance:
    Execute a command from command line to open driver door
    Thanks!
    You need hardware to do that.
    Fusion Brain, Phidgets, etc.
    How about the Wiki?
      i have to ask-- why do you want to do this from the command line? most carpc software is specifically focused at reducing driver distraction, and imo, using the comand line would go against that.
      next project? subaru brz
      carpc undecided
        just so i am clear, I can access Fusion Brain, Phidgets, etc to trigger an actuator via windows command line?
        the computer in the car will be running a webserver. The actuators will be controlled by a web user. Click a link on the webpage, execute program via command line, door opens
        again, "Fusion Brain, Phidgets, etc " all have this capability, so it doesnt matter which i purchase?
          No doubt those (door) controls are paralleled with the manual switch?
          (I know this is a redundant reply. Not that I know all....)
            You will need to do some research about the command-line functionality. I honestly don't know.
            How about the Wiki?
              For instance:
              Thanks!
              If you're asking if a front-end has the ability to execute commandline code, the Ride Runner front-End supports commandline interfaces. I have several buttons in my skins tied to command line code. Download the RR documentation and review the "skin commands.txt" sections on "RUN", "RUNW", "RUNQ", and "RUNQW".
              I believe the above items were mentioned because there are RR plugins supporting those devices, i.e., no need for a commandline interface.
              Good luck with your project.
                i have 4 mjs usbio1's controlling various pumps and actuators. I believe that they can be controlled via command line. you should ask mitch... he's the main guy in charge of riderunner as well as the developer of the mjsio1's
                New System in progress:
                M10k
                Phaze TD1500 ~> Seas g18rnx/p
                Zapco Ref 500.1 ~ 12" tc-9
                Transflective Xenarc
                My Car Pc Install
                My Boat Pc worklog
