I need PSU with about 850 Watt
  • I need PSU with about 850 Watt
    Hi
    I have a Carputer with Asus P8H67-I DELUXE and i7... etc.
    I need a PSU that will work with ignition and provide at least 850 wat. I searched, but did not find a way.
    Please,, any idea
    There is none.
    You have two options:
    1 - Use an inverter with a startup/shutdown controller
    2 - Use different hardware that draws less power.
    How about the Wiki?
      Lol 850W,
      I just bought that board. If i were you i would ditch the i7 and opt for an i3.
      Even with an i7 i don't think you'll need anywhere near 850w.
      The Opus 320 would certainly work for you, but i am planning that board with an i3 3.1ghz (should be here today) with a M4-ATX (250W) 3.5" Hard drive and many USB devices.
      Note my Zotac H55-ITX-C-E worked fine on the M4-ATX with a 3.2ghz core i3. I think your grossly overestimated your power consumtion. I would do the math again on one of those power estimator websites
      Remember this is a Carpc not a desktop system. You need to consider power consumtion in every aspect of your build. The core i3 will be far more processing power than you will need in carpc over the next 3 years (estimated product life) many people are more than happy with the Atom based processors.
        Actually, I think you can get it up to 850W Let's take a look!
        So let's say you are using Core i7-950. It can use up to 233W at 100% without OC (according to bit-tech.net)
        Mobo eats around 120W
        Since he's using Core i7, I can only assume he's also using a high-end video card. For instnace, GeForce GTX 570 eats around 330W under load.
        Hey we already got to 680W! Add up some peripherals, and we'll climb up to 700W no problem. And power supplies don't like to be pushed to 100% load, so 850W isn't unreasonable for that caliber of a PC. What is unreasonable is that caliber PC in a Mini-ITX formfactor, and even more unreasonable to put it in the car!
        Sorry, almatrodi, you might want to rethink this project. What are you trying to accomplish?
        My Project: All-in-one Double Din Unit
          I absolutely agree... 850W isn't unreasonable for that PC (with a powerful graphics card)... just the part about puting that in your car. I can't see why you would need anything close to a high end graphics card in your car to play DVD's videos and maybe viz, The onboard card should be more than sufficiant. Further more front ends like centrafuse don't even use hardware acceleration in the transitions and such so it is pointless
          Drop the Proc, and lose the video card and you will be fine
            Thanks to all
            What I have right now is:
            - Asus P8H67-I DELUXE 350W
            - Intel Core i7-2600K Processor 3.4GHz 8 MB Cache Socket LGA1155
            - 8GB DDR3
            - Toshiba Slot-Loading Portable SuperMulti Drive PA3845U-1DV2
            - Lexar Media Inc Crucial 128 GB m4 SATA 6Gb/s 2.5-Inch Solid State Drive CT128M4SSD2
            - Holux Mini Smart Mouse Type GPS Receiver GR-213U
            - Some USB powered items, such as USB Flash, USB HDD, iPhone, HD 7 ...etc
            About the VGA card, I think the built in one is enough for me
            How much Watts do you think it will be enough for this system?, and from where can I get it?
            I visited http://support.asus.com/PowerSupply.aspx?SLanguage=en and see. It gave me 350W, but in motherboard's specification, to make it work effectively at least 350W
              I ran two different i3 motherboards in the last year using an M2-ATX without any problems. I'm currently running a quad-core i5 sandy bridge with the same 2 year old M2-ATX I've had in my truck from day 1. No problems...works like a champ. And I suspect that the i5 is sufficently powerful enough to handle any reasonable in-car tasks.
              Sometimes more is just....more, not better.
              VegasGuy
                what are you planning on doing with this pc?
                next project? subaru brz
                carpc undecided
                  I was thinking of fast boot and response, I used i5 with notebook and it was awful, but I think I made a mistake
                  What do you suggest, use it as home desktop and buy another low voltage one?
                  right now, I am thinking of buying a 500W like http://www.alibaba.com/product-gs/43...Converter.html , and roll the dice
                    Well if you want to encode HD videos while playing dx11 games at max then yes, desktop it is. I would never put a system like that in my car with the chance someone steals it.
                      IMHO fast boot times have little to do with the speed of the processor or number of cores and more to do with the design of the MB, Bios, OS, MB HDD sub system interface and type of HDD and to a smaller extent the amount of RAM if using Hibernate.
                      There are times when you my want to listen to music with the engine off (waiting for Wife, GF or partner) or play around with or mod the system, that amount of power would be a killer.
                      The system Iím using absolutely screams along and drawís a total of 35 watts including all Microprocessor interfaces, Digital radio, GPS and LCD screen. Thatís with GPS running, Digital radio playing, OBDII diagnostics running, and interface microís running hi speed data access to various sensors.
                      With all sub systems running, the response to any hardware interface button or touch screen menu item is instantaneous. Thatís with an i3, I believe that later more powerful processors may draw even less than my older i3. Power dropped almost 8 watts with the same components when I changed to this later MB.
                      Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
                        edit: too slow. i guess this is just to add to what mickz said....
                        i think you are really mistaken as to what a carpc does, and needs.
                        speed:
                        1. bootup:
                        this depends on your hardware, and the way the bios is setup. the processor selection has little to do with this. there are fast booting boards and slow booting boards.. i can get a atom board that boots faster then a i7 board, and the other way around.
                        2. overall speed:
                        while there is a noticable difference between a atom processor and pentium, there really isn't much difference between a pentium and i7 (i have 4 pc's-- a atom board home pc, a mobile pentium laptop, a 775 socket pentium in-car, and a i7 gaming rig)
                        but again, the way the that the system is setup and configured affects the speed more then the processor. with the right tweaks, i can make a atom board feel just as fast as a pentium..
                        the difference between a pentium and a i7 is in very-very-heavy processing. like gaming, and autocad..
                        doing things like surfing the web, listening to music, gps, etc is not enough to even get the pentium to break a sweat. i doubt you would be able to tell a difference just browsing web pages between a pentium and a i7.
                        - 8GB DDR3
                        the board should be ok.
                        the processor is overkill.
                        the 8gb ram is complete overkill.
                        i run 2gb in car, and it is plenty for my heavier-then-average carpc use(i use the carpc for realtime audio manipulation).
                        also, if you ever plan to use hibernate, the smaller the amount of ram, the better. remember that when you hibernate, the pc needs to write all the data from the ram into the hdd. that can take quite a while even with 2gb..
                        this is good-- the slot load type is the best for car use, as there is a possiblity that a tray-load drive could break while loading a cd on a bumpy road.
                        i think that ssd should be ok--there are good and bad ssd's-- which can also affect speed..
                        i am not familiar with that gps receiver, though, i believe that as long as it outputs nmea(sp?) data, then it should be useable with any mapping program. if it outputs it's own version of data, then it is pretty much useless. the bu353 is the most popular receiver here, and has been verified to work with all the available gps programs.
                        carpc undecided
                          Hi soundman, don’t you just hate it when that happens, however your point about SSD speeds not being equal among makes and chipsets is another very important point that I overlooked.
                            eh, it took me about 2 hours to post that (dinner and other distractions) so it was kind of expected..
                            carpc undecided
                              Dear soundman, thanks very much for your details, I hope that I got before I buy.
                              Anyhow, I am thinking now of selling the i7 and 4gb ram, and buy i5. Do you think this will be a good solution?, or it is better to buy another whole configuration from scratch?
