New to this forum, Lotus Project.
  • New to this forum, Lotus Project.
    Hi,
    I am new to this forum. My current project is a 1973 Louts Europa that will have a Ford Zetec engine and I would like to add a full carPC system (tire monitors, boost control, music, Blu-Ray quality video, ect.). I am looking for input/help on the computer side of this project as my hardware knowledge is somewhat limited. Any thoughts?
    Jake
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Planning: ::::::::::::
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
    Install: ::::::::::::
    Oh, yeah, and build the car... ::::::::::::
    you've come to the right place, though, i'm not sure what to add-- try looking through the members ride area to get a idea of what others are running for a similar setup, or try searching for similar builds.
    next project? subaru brz
    carpc undecided
      Okay, I think I might be a little in over my head, but I'm up for the challenge. Here are my goals for my build;
      1. GPS nav system
      2. Phone integration
      3. Mobile wifi hotspot (built into the car)
      4. Games / Movies / Music
      5. Dual monitors
      6. Fully digital dashboard (no gauges at all)
      7. Ability to re-tune a MegaSquirt ECU on the fly
      8. Accelerometer
      Things that would be cool (secondary / future goals)
      1. A 26-32" HDTV mounted in the trunk (its a mid-engined car so heat could be a problem)
      2. Hook my PS3 to the trunk mounted HDTV
      3. Power the car from a standard 120-volt outlet
      4. Have a exterior Ethernet jack (to hardwire the car to my home network when the car is in the garage)
      5. Prompt for a password before starting the car
      Note: This car is going to be custom built, striped to the frame and rebuilt by me for me.
      Enter the LOTUS...
      (more info here)
      Pre-build thread
      Parts: ::::::::::::
      Build: ::::::::::::
      Test: ::::::::::::
        Originally posted by BoyRacer0013 View Post
        Okay, I think I might be a little in over my head, but I'm up for the challenge. Here are my goals for my build;[INDENT]1. GPS nav system
        don't know much about either, though haven't heard very much positive stuff about the current solutions.
        it might be easiest to install one of those 3g/4g internet boxes from a local cell phone company
        that one's easy
        5. Dual monitors
        so you want dual screens for media, as well as some screens for the gauges? that is kind of reaching the limits if my knowledge, but you might want to look at hardware with at least 2-3 outputs for the media screens, and then consider using either usb screen(s) for the gauges, or the route i see heavily recommended-- build a separate dedicated pc for gauges that is isolated from everything to minimize the chance of it crashing or having issues.
        8. Accelerometer
        the way i understand it, megasquirt needs a pc, so that requirement is pretty easy to meet. not sure where the gauge data can come from..
        i have seriously considered this myself-- recently, there are a couple of new tv's hitting the market--usually the super-thin ones, that use 19v power-- all that is required for one of those is a carnetix psu..
        this is best to locate in industrial parts suppliers-- like digikey, mouser, newark, allied, etc.
        not impossible, but highly recommended to keep independent of the carpc to prevent issues regarding boot times or software crashes.
        carpc undecided
          Have you decided on which from end you want to use as this will help in guiding you.
            I plan to use TunerStudio or something like it to control the MegaSquirt, and to display the gages. As far as screens go, I want one for the gauges ( mounted where the gauges would normally sit - 7" to 9" ) and one in the center console ( around 10" ). Should I be thinking about having two computers, one for TunerStudio and, one for everything else?
            Enter the LOTUS...
            (more info here)
            Pre-build thread
            Parts: ::::::::::::
            Build: ::::::::::::
            Test: ::::::::::::
              that would be a better question for the engine management section-- while i am familiar with the basic concepts, i just don't know enough about it to provide any solid advice.
              carpc undecided
                Okay, I have also started a thread here on the MegaSquirt / dashboard end of things.
                Enter the LOTUS...
                (more info here)
                Pre-build thread
                Parts: ::::::::::::
                Build: ::::::::::::
                Test: ::::::::::::
                  So you want to replace the actual speedo etc. with a screen as there has been a few attempts at this type of thing but I would remember that computers do not always behave like they should and to rely on one all the time for critical infomation could have repercussions.
                    I am aware of the possible reliability issues inherent with this type of setup, I intend to thoroughly test and debug the system before I rely totally on it. I am aware of the main problems with what I am doing, I try not to do things like this without a lot of research and having all my questions answered before I start spending money. That said I am still in the planning / discussion / question asking phase of the project.
                    Enter the LOTUS...
                    (more info here)
                    Pre-build thread
                    Parts: ::::::::::::
                    Build: ::::::::::::
                    Test: ::::::::::::
                      Sorry if that sounded mean MagicMan.
                      Enter the LOTUS...
                      (more info here)
                      Pre-build thread
                      Parts: ::::::::::::
                      Build: ::::::::::::
                      Test: ::::::::::::
                        All is good
                          Okay so I think I have a setup picked out:
                          Monitors:
                          • Center console - Lilliput FA1011-NP/C/T
                          • Gauge display - Lilliput 869GL-80NP/C/T
                          • Tuning monitor - HannsG HK162ABB 16"
                          The computer:
                          • Motherboard - ASUS F1A75-M
                          • CPU - AMD A6-3650
                          • RAM - Patriot Viper Xtreme Performance Desktop Memory Kit - 4GB (2 x 2GB)
                          • SSD - OCZ 60G Vertex 3
                          • Power Supply - Ultra X4 Micro ATX 400W Modular
                          Other:
                          • Amp - ? (what do I need for an amp?)
                          • Speakers - Clarion SRG1021R
                          • Volume knob - Griffin Powermate
                          • GPS Receiver - BU-353 Weather-proof
                          • Bluetooh - ? (el cheapo one, do I need one for each device?)
                          • Keyboard / Mouse - HiRO 3-in-1 2.4GHz WiFi Wireless QWERTY Keyboard
                          • Power Inverter - Whistler PRO-800W
                          Any input on the setup, and questions? Dose any body see any thing I can replace with something else to make the project a little easier?
                          Enter the LOTUS...
                          (more info here)
                          Pre-build thread
                          Parts: ::::::::::::
                          Build: ::::::::::::
                          Test: ::::::::::::
                            i know this comes in a kit, so not a big deal, but usually 2gb is plenty. if you plan on using hibernate, then you want as little memory as possible, as the more memory you have, the longer the hibernate and resume times will be.
                            instead, use a dc-dc power supply- it is much more efficient, because it drops the ac conversion of a inverter setup. while the cost is similar, this option also gains a startup/shutdown controller, so getting the pc to boot when you start the car is simplified.
                            just one that meets your speakers-- there are many people that are happy with the super-small 'motorcycle amps' off ebay-- they claim to be just as good/better as the factory equipment, and are quite cheap. though there is no reason not to get a better car audio-specific version.
                            while i don't use it, i have tried it occasionally-- you should only need 1 module for all the devices.
                            carpc undecided
                              As far as the RAM is concerned I plan to run a VM that runs my front end, that will use half of the memory. The reason I am thinking about using an inverter is because if I need to run a video card ( I don't know if the on board will do the trick for all 3 monitors ) I will need more power than any of the DC-DC power supplies can provide. An other option is to run two of the DC-DC supplies in unison ( I have done this on a desktop before but I don't know if it makes sense / is possible to do it here ). For the Amp I don't need much 15 or 20w should be enough, I don't want ( or need ) my car stereo to be super loud - I will look at Ebay tomorrow and see what I can find.
                              Enter the LOTUS...
                              (more info here)
                              Pre-build thread
                              Parts: ::::::::::::
                              Build: ::::::::::::
                              Test: ::::::::::::
