Starting small, installing a single-din stereo in my 2009 Subaru Impreza
  • Starting small, installing a single-din stereo in my 2009 Subaru Impreza
    After looking around, I decided that I would like to copy the following design
    Click image for larger version
    Are there any pointers of how to install a stereo in an unconventional location?
    Four that I can think of:
    1. Make sure there is ventilation space around the case, especially if you are using the internal amplifier
    2. Make sure it is mounted solid and not just hanging off a front flange or something. Add a rear strap to it if the front mounts do not have attachment points at least 1/3 of the way back on the sides.
    3. Check your depth of the space versus head unit first.
    4. Check your angle of the face plate for sun reflection issues and try to adjust if necessary. It's more fun when you can read the display in the sun. Yes, I guess I am a poet.
