Hey guys need some help with carputer install
  • Hey guys need some help with carputer install
    My base is going to be a laptop since i had one lying around that i could use. a few things im stuck at, one how would i connect the car speakers and my subs to the laptop? two whats the best software to use.
    you need a amp. and then you just use a 3.5mm to rca adapter cable to split the signal up to the different amps.
    what kind of software are you looking for?
      So a regular 4 ch amp for speakers then? How many watts? And like roadrunner whats the best one to use on it, thanks
        also does it matter if i get a vga touch screen vs a usb one?
          Assy, check out my thread, similar idea, except i used a pc rather than laptop, and with the help of the great guys on mp3car, i think it worked out quite well.
          http://www.mp3car.com/vbulletin/newb...wbie-here.html
          For your touchscreen, it will use usb for the touch interface... the video to the screen will go through either d-sub, dvi, or hdmi
            oh i thought it all went from the usb, what monitor do you recomened
              ok i got my amp installed and ordered the gps dongle and the bluetooth also a usb hub. now would this be a good screen?
              http://www.google.com/products/catal...ed=0CH0Q8wIwAQ
              and what would i use to turn the laptop charger on and off like a pc would?
                sorry, i missed your other posts--- stupid moderation que(not the fault of the mods, but the fault of the forum software for not showing it as a new unread post later on)...
                that screen doesn't have a touch screen. i recommend the lilliput 629, or lilliput 669. both have worked excellent for me.
                beware, usb-only screens will not display any info before the pc loads the desktop, so any pre-desktop errors will never show up.
                for power, the best solutions are to use a carnetix 1900, 2140, or dc-dc usb.
                  damn that screen is 200
                    Not the one you have shown above...
                    get one of the ones that are listed in the store here, which support touch control etc.. and that suits the size you need.
                    For me the one i got was perfect, though a transflective one would have been nicer
                    http://store.mp3car.com/Lilliput_619..._p/mon-001.htm
                    or
                    http://store.mp3car.com/Industrial_G..._p/mon-068.htm
                    though you would want to be very serious about it to get the second one.
                    There's a slightly cheaper sunlight readable one, but it only has a 60 day warranty = forget it
                      or
                      thanks for the links but i was looking on ebay and came across this
                      http://www.ebay.com/itm/120813574274...84.m1438.l2649
                      looks good for the price what do you think
                      on a side note i hate waiting for my posts to show up lol
                        that one looks fine-- i have seen that model pop up from time to time. no huge negatives as far as i can remember..
                          ok sweet ill go with that then thanks
                            will the bluetooth work with the built in mic on the laptop? if it will ill remove it from the board and add some wire and move it
