Please Critique My Idea
  • Please Critique My Idea
    Feel free to yell at me and tell me I'm wrong if this wont work. I have a 1998 Honda Accord. Currently I have the Kenwood DPX308U in there and like it, but im thinking about moving up to a carpc. My plan is to use an old Acer Aspire 5050-5430 laptop that I have laying around. It has the 1.7GHz Athlon 64 X2 Dual-Core TK-53 processor in it.
    First Question: Is there a pressing reason that I should use Windows 7 over Windows XP? I have access to XP with unlimited licenses, but not W7.
    The screen I plan on using is a Lilliput EBY701-NP/C/T with the double-din mount on it from MCS on eBay. It's the 2012 model with the LED back-lighting.
    http://www.ebay.com/itm/160701820015...84.m1438.l2649
    Second Question: How would you rate this screen? I've heard good things about Lilliput's and this one comes with a free anti-glare screen protector as well.
    Thanks,
    Matt Prenger
    Welp. Just bought the screen. Will post back on how it looks.
      can't comment on the screen, but I wouldn't use a laptop. from what I read standard drives will fail if you hit a bump, plus laptops heat up a lot and may overheat if you put it under the seat
        I can't think of a reason to run windows 7... or XP for that matter.
        Former author of LinuxICE, nghost, nobdy.
        Current author of Automotive Message Broker (AMB).
        Works on Tizen IVI. Does not represent anyone or anything but himself.
          Well I'm going to disagree with you on this one. Except for maybe the laptop being used, I'm not sure how the Acer is built or how that X2 processor deals with heat.
          I've got an HP TC4400 TabletPC in my car, and *knock on wood* have had it running for nearly 3 years without a harddrive failure. This is in my lowered car, with the laptop base sitting in my re-fabbed glovebox... no additional padding or cooling. That said, laptop drives are built to accept slight shock and motion, much better than desktop drives. Step up to an SSD and you're set for off-roading!
          Now I have recently moved the base of the laptop in behind the screen, and am now starting to notice that it's running hotter... so I'm just going to install a venting fan, as the area is a bit tighter with more electronics generating heat.
          How do you plan on powering the laptop? Turning it on and off? How does the laptop handle outputting video externally all the time?
          I use the Carnetix P1900 to handle the power and on/off. Does the Acer have one of those 'smart' pins? Monitor output isn't a problem for me since I'm using the standard screen, but I know if I was to move to an external monitor I'd either have to do a 2-button press each time, or the simple way, place a magnet overtop of a sensor to tell the computer the lid is closed... like with a docking station.
          What are you planning on doing for a frontend? Are you going straight from the laptop into an amp, or keeping the deck you have and using the aux in?
          Couple things to think about....
          ...aaaand.... now I"m done
          03 Hyundai Elantra GT {Worklog}
          HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
          RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
          cmdRR tall skin creator
          86 Pontiac Fiero SE 2m6
          possible carpc install
            Definitely disagree with LGHT.
            Laptop hard drives (2.5") are actually MORE resilient to shock and in general, laptops consume less power and produce less heat than desktops. Laptops are in a lot of ways a better solution than a pieced together kit on a standard mobo but there are a lot of reasons to go the other way too. I have done 2 laptop installs but I would never tell somebody NOT to use a desktop. Check the wiki for good reasons in both directions.
            If you have XP, use it unless you need more than 4 gigs of memory. The only other feature you could possibly want would be hybrid sleep. Don't let the Linux guy bother you I love linux and use it extensively but windows has its place in the event you don't want to be a nerd. JK tripzero
            I have a 701 and it's a good looking screen but I have an anti-glare optically bonded transflective upgrade. I don't know how good those antiglare stick on units work but I suspect you will have difficulty on bright days and it will probably be duller looking with that film installed.
              That should work alright for you, but be aware you're going to have to either get a carnetix DC/DC to run the laptop, or an inverter, which I highly suggest against.
              What frontend are you planning on running? If you're going for CF or RR, you may want to get a slightly higher power CPU, and if you're running CF, then definitely a laptop with a better video processor inside, otherwise you may experience lag issues.
              RevFE
              My Shop
                Really? Athlon were fast little buggers. I remember recording over 10 tracks at a time on an Athlon 1800+ back in the day. http://www.cpubenchmark.net/cpu_look...ual-Core+TK-53 puts it above all Atom processors and I know lots of people run them around here.
                  Sure, it's faster than an Atom, but have you tried to run CF on an Atom?
                  RevFE
                  My Shop
                    Quit confusing the new guys about hard drive durability.
                    The best reasons for 2.5" drives (laptop) are physical dimensions (smaller) and power consumption (less). That comes at an increased price at purchase.
                    We have not had ANY actual proof that they (laptop drives) last longer than a desktop drive. No one has done the lab tests and the tear down to determine root cause in the real world, just conjecture.
                    When planning an install considering price, physical size, storage size, power needs, and cost are great. A quick search on durability will show the lack of real evidence indicating one form factor will last longer than the other.
                    Cheers
                    TruckinMP3
                    Read the FAQ!
                      UG seriously, we are going to do this again? 2.5" HD typically are rated for higher shock than 3.5" drives. AND so nobody can flame me... here are two PDF's from Western Digital proving it. First is 3.5" WD Caviar Blue, Second is 2.5" WD Scorpio Blue. Both are of the same "series" AKA BLUE but 2.5's are scorpio and 3.5's caviar... I digress.
                      3.5" 30 - 65 OPERATING Gs or 300 - 350 non operating
                      2.5" 350 - 400 OPERATING Gs or 900 - 1000 non operating
                      BIG difference so it can't be said that caviar and scorpio are apples/oranges in series'.
                      http://www.wdc.com/wdproducts/librar...879-701277.pdf
                      http://www.wdc.com/wdproducts/librar...879-701278.pdf
                        Sure, How many Gs of shock are the driver and car rated for? Book specs are great, they are not proof one is better than the other in a car. Not disputing your numbers or the factory specs at all.
                        If you have been in any other HD threads you will have read my personal history with wrecked cars, bent frames and a desktop drive that is still functioning after being in use when the frames (boxed ladder type and yes, plural) bent.
                        Deal with it.
                        A far more likely cause of HD failure in a car regardless of form factor is poorly regulated p0wer. Nope, I can't 'prove' it or change your mind. But you cannot disprove it either.
                        Did you enjoy your spoon?
                        TruckinMP3
                        Read the FAQ!
                          I never disputed if a 3.5 would handle the g's of the road or an accident. Surely the hard drive is rated for more g's than a human body. I simply pointed out my statement was in fact FACT.
                          A 60 mph crash with a stationary object will have around 30g's (assuming .1 second deceleration time)... at that point the human is not feeling well if anything at all and even the 3.5" hd is still within spec. So, you are correct; the only proven reason to go with a 2.5 over 3.5 would be size and power consumption. But, if I had a 3.5" drive or a 2.5" drive to choose from all things equal... I would take the 2.5" because it will by definition handle the stress of the road better in edition to its reduced size and electrical consumption and increased speed. Would I pay more for it? No.
                          The fact that you have wrecked multiple cars(as I gather from your semi cryptic statement) with a hard drive on board proves little other than you are lucky and likely either a poor driver or an odd combination of lucky and unlucky at the same time. Certainly not dissing your driving skills, but without further details I have little to go on.
                          There is a reason IBM and other manufacturers put effort into parking the heads on their hard drives when a laptop detects it is free falling. Probably not because their research said you were guaranteed to loose the hard drive but rather it wasn't worth the risk.
                          Not sure about the spoon... some weird matrix joke or are you trying to be rude? Either way you can keep it.
                            If you two want to argue about the merits of 2.5 vs 3.5 drives, go ahead, however it is out of scope for the topic of this thread, so you might do well to create a new thread to do so rather than clutter up this one. This guy is using a laptop, he's kinda limited to a laptop drive, regardless of which is better.
                            RevFE
                            My Shop
                              Well, how does it look?
                              TruckinMP3
                              Read the FAQ!
