the first chapter to my more advanced life. help
  • the first chapter to my more advanced life. help
    hey everybody,
    I've been lurking on here for the past few weeks, and i have finally decided to take the plunge. i went out and purchased a gently used system. i got a 1.6 ghz intel atom it came with fm, sirius, gps, and the monitor. i need help with a few things though. i already have a mono amp with four gauge wire so i plan to run that 4g to a distrubution block down to 8 ga and run my pc 4ch amp and my mono. how do i connect the 8 ga to the wire on the pc. its only 14 or so. also for my acc wire i will need 3. i have found that im going to need to use a relay. how do i get 3 wires off of a relay? and finally my last question it came with a lilliput screen but unfortunitly i have a single din and at first i thought i would be able to modify it so it would sit out of the din similar to aftermarket headunits but im not sure if i will be able to. has anyone here used the xenarc 700idt? are there any other vga touchscreen one din models out there? thank you for all the information you guys have already provided me i look forward to having this up and running
    i do apologize for the poorly written post
