gettig ready to solder my wires
  • gettig ready to solder my wires
    OK so I am debating...May be a stupid question but I am thining this out. Is it better to run from my amp to the speakers directly or just go into a wire harness. What if I just ran the rear speakers directly from the amp but used the wire harness for tihe front speakers?
    functionally, either would work. i guess it just depends on where you plan to take the install.. if you're planning on changing vehicles a year or two down the road, connecting the amp to the harness is better to allow everything to come apart easiest.
    but running new wire to the speakers off the amp is going to give you the best sound quality.
    next project? subaru brz
    carpc undecided
