Ok - Monitor Help
  • Ok - Monitor Help
    So I am tired of dorking around. I want to buy a monitor...$200 and under...help me find one...something that can be used for average uses...not really worried about playing movies on it...can handle sunlight whether it is really bright or a sun right readable monitor...aaaaaaaaaaaaaaaaaaaand GO!
    Touch?
      Yes...sorry was out on vacation hadn't checked the forums while I was out
        I am very happy with this monitor http://store.mp3car.com/Lilliput_669..._p/mon-123.htm for the money. The touch is much more accurate with the 5 wire vs 4 wire. The brightness is good I have in my dash of my truck, it is a bit recessed so it's sort of sheltered from the sun but readable in sunlight somewhat. I think you need to spend quite abit more for a true sunlight readable. Good luck SNO
          HEre are a couple I have started to consider -
          http://store.mp3car.com/High_Brightn..._p/mon-137.htm
          http://store.mp3car.com/Lilliput_669..._p/mon-124.htm
          They are similar...but different...can you help me decide?
          Of another suggestion?
            Go for the middle one it has a much higher brightness level at 450nits and 5 wire touch which makes a world of difference vs. 4 wire. Good luck SNO
              If I wasn't to go with a liliput what else could you recommend similar to these? I heard some people are going with this blackboard monitors now.
                Blackboard meaning chalk-electronics ? ...if you can get one their good..mine is good but far from perfect all the chalk stuff is open frame too.
                  Yeah Sorry...not sure what i was doing last night when i typed blackboard...goober move on me
                    I went ahead and got the 7 inch High Bright 5 wire Liliput
                      You will be happy with that monitor. I know I am. SNO
                        Now i need to figure out an interface!!!! Front end I mean
                          I vote for Driveline simple all the functions and support for all popular stuff SNO
                            Thanks SNO. :-)
                            Draco, give DriveLine a shot. Nothing to lose, right? It's free. There isn't even an installer. Just unzip the app where you want, and run it. It's open source, and it works pretty well.
                            It seems like there are only 3 or 4 front-ends left in active development. So DriveLine has at least a 25% chance of being the one for you.
