The length of the cables...
  • The length of the cables...
    Could someone post a sticky messagge that contains the max lenghth of a cable? IDE, USB, Ethernet and so on... it'd be useful fro everybody, not only newbies...
    Usb is about 5m, also usb2
    Ethernet is 100m something
    IDE is what, half metre? Some members on the forum have working IDE cables that reach the ground from a three-floor building, so dont take that too seriously.
    It simply depends on how much interference and shielding
    My cars
      Ok, I knew these... It was a suggestion for the newbie section...
      For example: VGA? LCD cable? and so on...
        Well, here it is, keep posting
        My cars
          Or find it yourself on google:
          ie: "max ide length"
          "max usb length"
          You probably won't need anything more than 15ft in a car. USB, Serial, VGA will work fine at these lengths.
          If you need to place the hd/cd rom far from the motherboard, you can use a usb 2.0 adapter or firewire.
          -TJ
          Smart Playlists Plugin for RoadRunner
          CarPC - 05 Acura TL Navi (pics soon)
          Retired CarPC - 03 Infiniti Qx4
            recommended length of IDE cables is 18"
            but some people made custom, longer cables and dont have any problems - just search in this forum and you'll find the answer
            Danny.
            "If today was perfect, there would be no need for tomorrow."
            My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
              Actually, USB2.0 is 15 feet, and you can get "active" extensions which will give you up to 25 feet.
              IDE is limited to 24 inches.
                5m is 15ft. But keep in mind, these standards are beautiful, but are only "safe" values. this doesn't mean it will work at the given value nor that it can't work over a certain value. best bet is just give it a shot and hope it works.
                I don't know for firewire, but pretty much all other computer based cables can be stretched the length of a vehicle (15ft or so) without a problem as long as they are shielded. Only exception would go to regulated 12v power cables and antennas which should be kept to a minimum to keep interference out.
                Mark
                Website: http://www.greenpowerenthusiast.com/
                Car'Puter Project
                - Xenarc 700TSV
                - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
                - 1x 256MB Corsair XMMS DDR400
                - M2-ATX
                - Belkin 802.11G W-Nic
                - Garmin 15H GPS
                - WinXP SP2 (NLited)
