music without head unit
  • music without head unit
    yeh this is my first post. i'm new. i'm starting my car pc project and i've gotten everything. i just wanna know how to get music without a head unit.
    You need an amp, and you run the computer to that and use the software volume control.
      okay i have a Rockford amp, one of those new 1500 watt ones. whats volume control?
        LOL. Stops your ears bleeding.
        4x4 in a turbo stylee.
          the volume control is the same thing you use to adjust the volume in windows.
            Mk3 of my carputer didn't have a head unit and I used the volume control of Windows to increase/decrease the music.
            Worked fine!!
            Hope this helps.
            Best regards,
            Darren Thrower
            http://www.percyt.com/mp3player.htm
              okay you say you plugged your computer into your amp..
              then where do all of the other wires go.. i mean the wires that are supposed to connect to the headunit. erg i'm confused.
              o and this is the amp i have. can anyone tell me if it works with the computer to amp thing with no head unit:
              http://www.bestbuy.com/site/olspage....oryId=cat03085
              thnx
                thnx
                Okay, do you already have the amp connected to your system? Is it powering all your speakers? If not, you're going to need to pick up another amp. It looks like that amp will only run two speakers (or one, bridged). If you've got four speakers and a sub, you're going to need at least a three-channel amp as well as that one you've already got.
                Normally, RCA's go from your head unit to the amp, then speaker wire to the speakers. Now, you want to run RCA's from your sound card in your computer out to the amp instead.
                Regarding wires, what other wires to the HU are you talking about? The power and remote wires? You can just ignore them, cap them or tape them up to prevent shorting.
                Good luck, and have fun.
                Kris
                How Much Horsepower Can I have And Still Go To Heaven?
                  have a look at my project : http://www.mp3car.com/vbulletin/showthread.php?t=18353
                  used different testing setups
                  a simple line mixer with headunit
                  or 5.1 sound from mobo or 5.1 sound from maya5.1 usb soundlevel controled by griffin powermate
                  everything is possible
                  home is where your heart is
                    damn might as well get a head unit then.. yeh my amp is only 2 channel. haha now i'm debating to see which way would be cheaper.. head unit or another amp..
