Laptop HD Question
  • Laptop HD Question
    Does anyone know if there is an adapter available that plugs into the 2.5" HD bay of a laptop computer and allows you to connect two hard drives simultaneously? My girlfriend's hard drive is crappin out and i'm gunna need to duplicate her data onto a new drive when it gets here.
    Thanks,
    -Josh
    Some ibm thinkpad can have 2 hdd's connected at the same time.
    USB cases for laptop hd's are really cheap, so that might be the road to take instead of messing with cables and risk the bus of a laptop.
    http://www.tigerdirect.com/applicati...asp?CatId=1204
    If there are usb, thats the way to do it
      I dont think 2 headed laptop HDD cable exist...Ill like to have one anyway
      If USB HDD is not right for you then you can just get a 3.5" to 2.5" converter and use your desktop to backup all the data.
        Yea, I was thinking of using the ide converter but was wonderin if there were any other ways. I guess i'll just do that since i'm probly only going to need to do this once and those things only cost between like $10-$20.
        Thanks anyway guys,
        -Josh
          I got my IDE covnerter for 5 bucks. It's useful. Try your local store.
          - Lwin M. Maung
          If it's stuck, force it. If it breaks it needed replacing anyway
            I thought there is a 44-pin IDE cable with connections for 2 laptop(SFF) HDDs like their 40-pin equivalent for desktop HDDs.
            http://shop.store.yahoo.com/cableson...driv44pin.html
              "I thought there is a 44-pin IDE cable with connections for 2 laptop(SFF) HDDs like their 40-pin equivalent for desktop HDDs."
              So they did exist...cheers I just couldnt find any when I was looking for one.
