os and input recomendations 4 low spec pc
  • os and input recomendations 4 low spec pc
    what ive got:
    AMD K6 300mhz
    64mb sdram
    2 x 1.2gb hd's (im looking for a free 10gb or so)
    yamaha pci sound card
    pci s3 virge video card.
    at power supply but the mo bo takes at and atx
    what I need:
    a dvd drive...whats the story, can I use a tray style one?
    a monitor...hows this look?
    http://cgi.ebay.com.au/ws/eBayISAPI....category=14946
    an operating system...recomendations?
    a controller....recomendations?
    cheers fellas
    go look at college surplus stores for 10gig hard drives in the $5 range.
    Tray load technology doesn't magically not work on the road...what are you going to do with it that you are asking about? Also, 300mhz is gonna be pretty slow for DVD watching unless you have a hardware decompressor, and even then it might be iffy...somebody correct me if i'm out of line here...
    That monitor is fine, similar to what I have...but does your video card have TV-out? That monitor takes a single RCA video cable, not a VGA...
    If you're going cheap, for power, get an invertor and make that work.
    300mhz is pretty slow...I don't have any experience with that, but if you don't know Linux, I'd use win2k lite.
    What do you mean by a controller?
    Good luck
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
      Windows 3.1.1.1.6
      BOOOYAAA!!!!!
      Only the Super Pimp use Windows 3.1 for their mp3players
      Originally posted by menudude
      thank you all for your help minus the useless post by sjlucky...
        are you talking ****?
          What do you plan to use the computer for?
          With the computer you have right now I probably would not wan't to run anything other then Windows 98. Windows 2000/XP won't really run the best.
          DVD playback will not be the best IMO. I once had an AMD 300 system and while playing dvds it was a little jerky.
          Yeah and also as someone has already mentioned you will need an graphics card with TV output if you don't reeady have this?
          CarPC: Currently in progress...
            2k will run fine...but you need to bump the memory to 128 or 256 to get anything done.
            DVD is out...Divx out...small mpeg files ok...moving map/mp3 no problem.
            Actually I am not sure if DVD will work or not...
            current projects
              Originally posted by telekineticfool
              ...Also, 300mhz is gonna be pretty slow for DVD watching unless you have a hardware decompressor, and even then it might be iffy...somebody correct me if i'm out of line here...
              ...300mhz is pretty slow...I don't have any experience with that, but if you don't know Linux, I'd use win2k lite.
              Actually, the thing that plays DVD is the CODEC processor that is in your Graphics Card, and a higher Bus speed of the Motherboard helps. 300MHz for a Carputer is not that really slow, it only depends on what you wish to achieve. My system has a 333MHz CPU and I even underclocked it to 233MHz to reduce heat and power consumption. Over the years I have learned that efficient, low power consumption (hardware) is the best option as it elliminates every power problems in a car setup.
              Danon
              My Carputer Setup
              [....99.9%]
              [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
              [....99.8%]
              [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
              [Working on] puttingBackEvrythg.
