Radio through the CarPC
  • Radio through the CarPC
    I've done a , and can't find anything. I'm wanteing to listen to FM radio through my CarPC, but can't figure out how to do it. Any help would be appreciated.
    Greg Hager - 1992 Mustang LX 5.0 - http://hager.no-ip.com/ - http://www.ghager.com/
    Hippoauge (spelling?) sells an FM tuner/TV Tuner card for fairly cheap. I don't know that i've ever seen a radio tuner card without also having a TV tuner.
    just go to www.froogle.com (google's shopping portal) and type FM Tuner Card, you'll get lots of options.
      D-Link dru-r100 usb radio are supported in mediaengine and more are coming. If any of these are the frontend you want, then go for that. Do a search for d-link radio on the board, this will bring you plenty of info....
        Thanks for the answers, I'm still up on which front end I want to use, but it will be either MediaEngine or MediaCar. What FM options does MediaCar support?
          Currently none, but there are a workaround, using radiator. Look in mediacar forum for info. Mediaengine have full support for it.
