Slimline CD IDE/Firewire power question.
  • Slimline CD IDE/Firewire power question.
    I'd like to connect the following:
    HP laptop cd/dvd -> slimline to IDE adapter -> IDE to Firewire bridge -> mobo.
    I've done some searching but can't determine if the the laptop drive will receive power from the firewire bridge.
    It's seems that you need to power a full size cd drive separately but I don't know if the same is required for a laptop drive.
    Sometimes, always, never ....
    The slimline to IDE adapter is where the external (PSU) power is required.
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
      OK. I just got the adapter but it didn't come w/ any documentation.
      In the picture below, is the part with the arrow get connected to a floppy power connector?
      I'm assuming I got all the other parts correct.
        Well one is cd audio... the other is power...cant really tell you which one is which
        current projects
          Yeah, The one you have the arrow pointing to is for a floppy-sized molex.
            Thanks!
              the middle one isn't cd-out ... i'm pretty sure it's the jumper pins for setting master/slave/cable select ... most drives default to cable select.
              My JeepPC Install
              "there are no stupid questions, just stupid people."
              "it's been agreed the whole world stinks so no one's taking showers anymore"
