using a laptop...
  • using a laptop...
    im new to all of this and i plan on using a laptop... as i did my searches on how to power it, almost everything i found was for an opus, but from what ive read/understand from reading is that is for regular comps... is there an equivilant for laptops or how else would i suppy power to the laptop?
    This is what I got, works great!
    No need for a tank circuit, laptop will run off of internal battery while starting the car (so even a crappy laptop battery can be ok).
    91 Stealth RT/TT
    CarPuter: Inspiron 5150 P4 3.0ghz; Built-in WiFi; Deluo GPS; Radio Shark; OBD1; Nostromo Speedpad
    Audio: Audigy 2 NX; Clarion 500.5 amp; 100.2 center channel amp; Kicker Solo-baric L7 10" Sub
    Display: Lilliput 7" Touchscreen
      You could use a power inverter directly connected to the battery, then simply plug your AC adapter into the inverter and run it from there. If you want I actually have one for sale. Check out my ebay link
      New CarPC on the way again I think. I miss my old one!!!
