Need Help With Power
  • Need Help With Power
    I have a small Cappucino PC, that uses a brick power supply. The brick AC adapter has the following specs:
    AC Input 100~240V ~ 1.8A, 50-60Hz
    DC Output 18~24V - 3.2A Max. or 60W Max.
    Typical output 18V
    Does anyone know of any solutions that will replace the brick and allow me to use the auto power off feature of other DC boards?
    There is a laptop adapter that IIRC Radio Shack sells which can output 18V. Then, for the shutdown controller, use the ITPS
    Welcome to the forums, btw
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
      The cost is $200 but well worth it!
      http://www.opussolutions.com/150watt.html
      MVC www.mobiletvsystems.com/
      Check out the shop if your in the Maryland DC VA Area
      2004 Mazda 6s 3.0L
      Epia Via M-1000 512MB
      Opus 150W
      Samsung 80Gb ATA133 7200RPM
      New XenarcTSV
