Amplifier Needed?
  • Amplifier Needed?
    Is an Amp needed to power a carputer? or can it run directly off the battery?
    Is the amplifier only needed for the speakers?
    You can infact run a carpc without an amplifier.
      Mind if you elaborate a bit...
        Go read the newbie FAQ sticky in this forum, it will answer your questions.
        to summarize:
        You run a power supply either off an inverter or a dc-dc power supply that is wired directly to the battery. if you have a head unit with aux in or use a modulator or a tape interface, you don't need an amplifier. If you want to run without a head unit, you take the sound out of the soundcard and run it into an amplifier and out to the speakers.
        MP3 MR2 (click here for details)
        Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
        Software: Windows 2000, Media Engine 2.0
          to summarize:
          Awesome thanks so much. You clear up allot for me...
            to summarize:
            How is the sound quality if you use a fm modulator ? Anyone tested that ?
              Not wonderful. I had a modulated CD changer for a while. The difference between a real CD player and the modulated changer was night and day...I had them hook it up when I got a CD player, and never used it after the first time I tried the two back-to-back. Yuck!
              It's good enough for some people though...It will be about as good as a really clean FM radio station....So if you're ok with that...*shrug*
                i was wondering about that myself, thanks for clearing that up.
