OPUS 90W , I can not shut down my car-pc
  • OPUS 90W , I can not shut down my car-pc
    I got BIOS instruction for EPIA M-series but I got EPIA. It is different, slightly. I tried my best but the computer reboot after 2 seconds of shut down. No reply from Kris.
    Anyone using EPIA 8000 motherboard with OPUS power supply?
    It does proper shut down but it reboot again. I pull the fuse out to stop the computer because it will shut down (every 20 mins) and reboot 2 seconds after every shut down.
    My BIOS setup problem ???
    Ign ACC connection problem??? (I have connected to the cig lighter.)
    Please help. Everything else works great, it wount shut dowm completely.
    can't run the opus from cig lighter only. You need a constant +12v (like from your battery) as well.
      Make sure "Restart on AC Power Loss" (or equivelently worded) is set to No.
      You will also need it hooked up directly to the battery, and the IGN wire needs to be hooked up to your ignition.
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        nada
        I hook up the
        red wire to battary with 15a fuse in between
        Black to ground
        Blue to the cig lighter (put a switch in betweeen)
        It would not shut down. Let me go check the BIOS again.
          nada
          BIOS checked, auto restart --disable
            nada
            no, still rebooting
