Slim Slot CD-Rom Connection?
  • Slim Slot CD-Rom Connection?
    Quick one:
    just what exactly is this connection
    http://ko1.koonline.ca/ebay/UJ-815-B/104_0428.JPG
    and where can i either buy something to convert it to IDE or USB2.
    Its the connection on the back of my slim loading cd-rom,
    it says it's ide, but it's definatle a lot smaller than any IDE i've seen
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    I solved it (just a little newb aftershock)
    anyways, I need a notebook IDE to desktop IDE converter..
    ala http://www.mini-itx.com/reviews/2677R/page3.asp
    But which one do i need?
    I'm trying to go from the slimline Ide to a desktop IDE to a 44pin IDE to usb2 adapter to my computer. I have the IDE(44) to usb, I just need to get my slim CD Rom converted to IDE.
    Here are some i've found:
    http://store.yahoo.com/directron/cddvdadapter.html
    http://www.acortech.com/.sc/ms/dd/10...rtor%20Adapter
    http://www.idotpc.com/TheStore/Perip...t.status=green
    http://linitx.com/product_info.php?c...roducts_id=110
    http://www.emicrox.com/eShop/product.aspx?pid=947726
      Any of those except the HD one. I just ordered the directron one myself.
      Mine needs to be updated.
        actually it turns out you need a laptop to desktop adapter too...
        the entire conversion is as follows:
        slim ide---> 44pin Ide (laptop) ---> 40 pin Ide (desktop)---> Usb2
        Am i going to have any problems with it changing that many times?
          no.
          CarPC install is starting to come along again...
            So its slim ide to desktop ide to usb.
            TOTO
            How does the audio get to the computer, or does that also go through the ide to usb?
            Will i need anything else?
            http://www.buyextras.com/usb20hispide.html
              TO
              or.... Do it with a single product
              http://www.bixnet.com/usenforslcdd.html
              --Craig
                The pic shows that one needs a power supply?
                Also i wana stay away from the case bulkyness, cause its going behind the
                dash and theres hardly any room as it is.
                  Yep... DC Output: 5V. I believe one of the wires on a Molex connector is 5 volts.
                  --Craig
                    --Craig
                    But i thought with most USB connections the item gets its power threw the usb from the computer.
                    Like my usb hub, it comes with a power source but I dont use it, the usb powers it.
                      that only works for low power devices. Most usb hard drive and cd drives need additional power. There are a few exceptions but most of the time, you need more power. There are some enclosure kits for 2.5 hard drives that draw power from the usb bus but I dont think it is enough for a cd. Could be wrong though...
                        There are USB DVD/CD drives that don't require a power source other than the USB. The Targus Slim USB 2.0 DVD drive that I just received doesn't require anything but the USB for power.
                        2000 Monte Carlo SS - CarPC FINALLY INSTALLED!!!
                        CarPC: VIA EPIA-M10000, Xenarc 700TSV, 20G 2.5" HD, Opus 90W, Targus USB DVD/CD-ROM
                        Audio: Audigy 2 USB, Alpine 4 Channel Amp, 2 x Alpine 300W 6x9, 2 x Alpine 200W 6.5 (sub coming soon)
                          This drive is only 5V
                          yeap, there are tons of usb/1394 drives that do not require power to, but they are huge and are not slot loading.
                          What i was was trying to see is if i can get my slimline slotloading combo drive to work without a case and having to use external power.
                          Or does anyone know if there is a slimline case that will make it usable without power other than from the usb/1394? Im just going 3' the most.
                            Check the power requirement of the Laptop CD Drive, if it is less than 5mA then you are good to go, just connect the USB 5v to the 44-40 IDE cable and it will be powered off the USB.
                            Edit: Fixed Quote Tags
                              I'm pretty sure the USB spec is 500mA, not 5mA.
                              Twostep
