Carputer integration with HUGE car audio system, help please
  • Carputer integration with HUGE car audio system, help please
    Hello, excuse me if this might have been asnwered elsewhere (Whats a search button?)
    I have a pretty intensive car audio install in my Expedition. I want to remove the head unit, and run everything off the MII 10000 carputer I am setting up.
    Let me explain whats in the truck first,
    2- 3400 Watt Memphis Audio MOJO Monoblock amplifiers running subs
    1- 400 Watt Memphis Audio Class AB 2 channel amp running 8" midbass
    1- 400 Watt Memphis Audio Class AB 4 channel amps running front and rear 6.5 mids and 1" tweets in each door.
    4- Rockfordfosgate 3112 SUBS in a 12' ported enclosure. Hitting about 147DB
    (currently having to replace glue on glass to keep pressure controled)
    Ohio generator 260amp Altenator
    3- Optima Yellow Top 80amp hour / 1300 Cold Cranking Amp Batteries
    Dual 0/1 Gauge Power wire for postive and negative power system.
    1- 17" TFT LCD Flip Down Monitor in rear
    4- 7" TFT LCD Headrest monitors (not VGA)
    4in/6out A/V switchbox
    RF Wireless headphones
    PS/2
    Xbox
    Color rear camera
    Secondary single din DVD/AM/FM/TV Tuner in rear fabrication.
    I only mention the above to describe what I want to do and so you all know and might offer suggestions.
    #1. My truck hits 147DB (A jet flying over is like 142). The rear box is created out of 1" MDF, it was created this thick so that it doesnt flex or vibrate, the subs fire down, ports fire rear to the end of suv. I plan on mounting the MII-10000 mini-itx directly to the panel of the eclosure opposite the ports, its a good 4' x 30" panel. I plan on using no case, just ATC style motherboard standoffs (from a case) and screwing the motherboard right to the wood. I have heard that I could mount the hard drive verticaly, by mounting them directly to the wood, they would. In evaluating the mounting point, I'm going to be honest, the whole truck vibrates, the bass hits hard, I plan on using USB interfaced 3.5" IDE drives so I can put all the guts back into the external cases and move them, but currently plan on mounting them on the baffle as stated. Suggestions?
    #2. I have TWO 200watt DC-DC power supply's (I havent done the math yet to know if 1 is enough or not). I plan on mounting them to the same baffle. Because my XM reciever, TV/FM tuner, Keyboard/mouse, TV out box, Wireless RF remote control, GPS, and USB 5.1 Audio Processor are all USB powered, Plus my external 2 hardrives and DVD Buner, and 7" lilliput ts VGA, I also purchased 2 powered USB 2.0 4 port hubs that run on +5v that I intent to wire to the 1st and 2nd power supply so that a majority of these devices get there power from the 2nd power supply rather than the pass through from motherboard. I think I have handle on this, interupt me if I am wrong, but the first ps will be connected to the MB to force shutdown, the 2nd will attempt to shutdown (no mb attached) but will at least time out at the same as 1st. Suggestions?
    Now comes the questions.
    I want the output from the carputer to be able to feed the a/v box (If I can get it there, I can use the a/v box to send it to any of the other output devices) thats what the tv out adaptor is for (I know I have one onboard, but in my experience, you sometimes have to turn this on, the vga pass through tvout box is always on, so I chose this). I understand that Im not going to have a great picture on the other monitors, not for icons and desktops, but I was under the impression that once dvds/divx/vcd/video media was playing that this output to these tft lcd devices would be of acceptable quality. Suggestions? Comments?
    Now here is the part I dont know, I want the audio output to directly goto the amplifiers, this means 2 distint things, #1. I need front and rear RCA outs, and 1 SUBWoofer out. #2. That all of the other items in the car (ps/2, xbox) are going to have to pipe into the pc, and then back out the pc (audio directly to the amps) (video to the a/v switcher). Thats why I bought the External Processor (5.1), I see that it has (L/R) (surround) (Subwoofer) outputs on it via stereo miniheadphone, Im not sure about quaility, but I assume that Mini Headphone to rca cables would be used, and then y cables to break out enough connections. is the surround the same as a rear, or would one forget the surround output and split the (L/R) for the rears as well as front? Thats the output question. Now input
    I have the a/v switcher, so all the other aux devices will only need to be seen as 1 composite video, and 1 2channel rca feed. I'm assuming that I will connecting this Video/Audio output to the capture video/audio of the TV/FM Tuner card. (Hopefully whichever USB Tuner I get, passes audio to the computer via USB rather than another Aux in miniheadphone jack). That handles getting Video to the PC (only for the vga controller monitor, I can send the video to the other monitors direct via A/v) but audio has to goto the PC and through its volume control back to the amps.
    Now I have the XM Usb tuner that has a mini headphone aux in requirement, and the TV/FM Tuner may as well. Add that to the A/V input and Im looking at a minimum of 3 Aux IN connections to the PC? Are you all using some type of mini headphone jack Y connector and branching the inputs into 1 entering the sound devices AUX in connector? Suggestions? Comments?
    The USB sound processor I'm looking at, has a I/R and Remote for it, unfortunantly it doesnt remove and remote mount, its on the device's front plate? Does this mean that the Media Engine / MedaiCar / whatever software volume controls wont be able to control it? The onboard volume controls are bypassed? or is it a configuration issue? I'd like to hope that the I/R control just controls the onboard mixer volume, and I wont use it, as I allready have a ATI Remote Wonder that controls volume as well as a thumb mouse and application shortcuts) and the interface on the carpc software be it media engine or whatever? Suggestions? Comments?
    I have a laptop with the popular carputer interfaces loaded, not a single one passes the extra attributes to the XM tuner application correctly? Is this a known issue? or What? I havent bought the TV Tuner / FM Tuner yet? I have an adaptec USB tv/capture card that I will be using, leaving just the FM tuner needs, however the haupauge USB includes both and would save power I believe, any suggestions? So far I like mediaengine, it uses dlink for FM (so I guess the dlink/adaptec combo makes most sense, is the Dlink any good?
    I also failed to mention that the Liliput monitor is getting glassed into the double din stereo location, although I am toying with putting a datalux 10.4" in the area since fabrication has to take place reguarless of which I choose. is the datlux anygood?
    I have more, but I know this post is large, hopefully it will get some comments and then I can elaborate if I need to.
    John
    John, that post is huge. You say whats a search button, i suggest you find it, spending some of your own time to research your questions before asking always gets you better answers.
    I'll answer your volume question. That volume is independent of your sound cards master volume as set by MC/ME. Leave it on nearly full and control the volume with your software.
    Your HD is going to struggle, thats a hell of a lot of vibration, mount it as far away from yr subs as possible.
    Your composite screens will struggle wth small text/GPS but should be fine with DVD.
    You should consider the quality drop in VGA-RCA conversion. You should also consider the fact that by using dual monitor, or monitor/TV in your situation you can display different applications on different screens, i.e. media car on yr VGA screen, DVD on the headrests.
    1 200W PSU will suffice. If you use 2 u will need to do smoe solder/wiring to get it to turn on at the right time. ATX PSU's require a pulse from the motherboard telling it to turn on the main rails.
    As for your audio output, get a creative extigy or similar 5.1 sound card, m1000 onboard sound is known to be iffy. This will give u the outputs u need.
    Audio input, you will need to use a 3-->1 mini headphone adapter. Or get an audio selector. I think the adapter will suffice, pretty easy to make one yrself.
    Thats all im gonna answer for now. Do a searcha nd if yr still struggling then ask. Not before.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
      Yes, there should be a sign for noobs that says goto 'community forum' link in the left side menu, and then the horizontal bar/menu on top will have search on it....
      It looks like you are going ot have a fun project John good luck and dont hesitate to post some pictures of your progress so that we can give advise and see your crazy system.
      ciao
      DICE Los Angeles
        I'm not new to the forum rules forgive me though, Im in the middle of a move and using a palm and limited browser to post and read email until my computer gets unpacked (Im moving) sitting here, bored in the sun and thought I'd spit some text. As soon as the real computer is up, I'll log in and spend some time. Thanks again....
          Septic,
          You should NOT simply use a splitter on the audio out from the sound card. It will cause several things, but most importantly it will decrease both the quality and volume of the audio. You will need to invest in several quality external crossovers.
          You have a problem: sound good with music and movies, or sound bad with music and have awesome movie audio. I have a large audio setup as well (not quite as large as yours, and not nearly as expensive, and still in the works) and do NOT use surround, because most of what I do is music. I have not yet played a movie. My car only seats 2 though. Better figure out how to procede... As a personal opinion, considering your setup, I wouldn't use surround. There is a windows option to use quadrophonic, which sends stereo sound to the two sets of outputs, which can be fed to 2 crossovers (which is the way I do it.)
          ColdPhreze
          14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
          200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
          2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
            Then what would be the point of having a n00b forum then?
              I am a lot nicer now...back then i was sort of a noob myself...i guess i was trying to beat on the noobs to come off more pro...
              i apologize..i try to help as much has possible nowadays...here..i will goto noob section right now and help someone
              DICE Los Angeles
                Lose those rockfords man, they suck.
                  Also, you may like to know that the audigy 2 soundcards have timming correction, great for people who compete in sq events.
                    for some reason i always felt taht rockf. did not bump clear enough..a powerful but too smooch of a hit--talking subs here..anyone agree?
                    DICE Los Angeles
                      I disagree with this, as long as you have a decent sound card that will cope with driving several amps and decent quality cables there shouldnt be a problem (and as long as you dont split the cables too many times)
                      Signature: [==||========] 20% complete
                        In which case you would be better off using a multi-channel line-driver, such as the Vibe Deltabox
                        Leo
                        http://www.talkaudio.co.uk
                        A million people can't be wrong, right?
                        Well... unless they're all from the red states...
                          Thats kinda the problem, he's running 8 channels into 4 amps...
                            How do you do this? Dual monitor setup? Or do you mean actually have a seperate dvd player to drive the second video input?
                              that is a big system alot of bass, I am trying to do the same thing in my car. but why a 5.1 sound card why not a regular 2 channel sound card do the mini plug to rca conversion then go into a line driver, then into a three way x-over. i only ask this because it dosnt sound like he has the setup for surround sound and he seems really intent on having lots of music. has anyone ever measured the preamp voltage on a set of rca's form a computer I would be willing to bet it is real low I think I will measure that this weekend.
