Comparision of EPIA M-9000
  • Comparision of EPIA M-9000
    H I see most of u guys are using EPIA M-9000 model for the Mothr board ( i guess 0 . Just wanted to know the comarision between EPIA M-9000 and P3 1000 mHz. ( mother board from Gigabyte ) How different is it. Fast / slow or size wise. Never seen a EPIA M-9000 here in India. so incase u can help me out pls
    Commell LV-677 DC 6 x 6" Mother Board
    2.6 GHz; 1 Gb Ram
    120 Gb Laptop HD
    7" InDash Xenarc MTD - X7000 Screen
    Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
    Parrot MK 6000 & iPhone
    Re done the carputer...Into the Glove Box !!
    Most of the people here use the m10000 model.
    You can find the specs here:
    http://www.viavpsd.com/product/epia_...therboardId=81
    Here is a review of the board:
    http://www.epiacenter.com/modules.ph...howpage&pid=21
    The m10000 board uses a VIA C3 processor running @ 1GHz.
    This is a special CPU designed to consume as little power as possible and run as cool as possible. A pentium III CPU has more power but a C3 CPU is more suitable for special missions like a carputer project. They both are x86 compatible CPU's. Just to give you an idea the C3 consumes just 45Watts when it plays DIVX movies @ 90% CPU load while a pentium III could easily reach 65 - 70 Watts. The new generation of C3 processors (we will see them on the Nano-ITX boards) can run fanless @ 1GHz. So no direct comparison. You choose what suites you best.
    You can buy VIA EPIA boards everywhere nowadays.
    Check this site. They ship worldwide :
    http://www.mini-itx.com
    Hope this helps.
      Yes well i get an idea as what u r trying to put in. thanx for ur advice and help
      cheers !!!
      2.6 GHz; 1 Gb Ram
      120 Gb Laptop HD
