Via Epia Tc 10000
  • Via Epia Tc 10000
    Hello Im new here, yet i have been reading up on the mp3car scene for about 6 months so i kinda know whats up....
    And yes i DID use the SEARCH button but to no luck
    ok this is what i wanted to do... i have an Acura CL - Bose Steoro that has a input for the cd changer that i can change so it is RCA cables, but it also has an external amp to power the factory speakers,- it also have volume controls on the steiring wheel. and the area where the radio is now is about 7-8" wide and about 4-5" tall
    with that in mind i was going to go for
    Epia m10000 for the mother board
    opus for power
    lillnput for the lcd (touch)
    but i see on miniitx's site there is a "VIA EPIA TC 10000 1Ghz Motherboard with Onboard DC-DC Converter" and you can get the bundle deal with External 60W Universal 12V PSU and Power Lead so my 1st question is is the TC 10000 going to be a good deal? 149euro for everything sounds good to me
    will this bundle deal be good for a hdd and a dvd drive and some usb stuff lcd and is it all i need to buy to power everything?
    and has anyone got in to an accedent becouse they were using there carpc?
    Thanks for all the help.
    Mr.E AKA Pyr00 AKA pyr0000
    The best way to go IMO is a CARNETIX CNX-P1260 (http://www.carnetix.com/CNXP1260.html) + TC 10000.
    This will give you 60W (12V - 5A regulated) plus all the features an OPUS has and more for just $85. Use an 2.5" hdd and a slim DVD and you'll be ok.
    I hope I helped.
    Cheers./
      i allready have a hdd and its a 30gig 7200rpm ide 3.5" drive will that be ok?
        wassup,
        nice car
        my setup is about to be installed by the weekend.
        i'm just finishing up my fabrication.
        hopefully the tc10000 will power all my stuff.
        PM me if ya need some info.
        2001 Acura CL traded for a 2006 Subaru Legacy GT
        7" Lilliput Touchscreen
        NANO-ITX+m1-atx
        512 DDRsodimm
        60g SATA Laptop HD
        4x Apple DVDslot
        digimoto OBDii
        mS GPS
        mini BT keyboard
        relocated HU faceplate
          Go here and download the TC 10000 manual :
          http://www.viaembedded.com/product/D...herboardId=201
          At the end of the manual there is a table which states that the onboard DC-DC PSU can cope with a 3.5" hdd and a desktop dvd drive (very interesting)
          Appendix C
          C-4
          Power Consumption (With IDE)
          Power consumers:
          • EPIA-TC with C3 Nehemiah 1.0 GHz CPU
          • Memory: Transcend W942508CH-75 256MB DDR266 SODIMM CL2.5
          • HDD: Maxtor D740X-6L 40GB ATA/133
          • DVD ROM: ASUS DVD-E616/ASUS/16X/G
          Idle State, +12V-Input, Total Watts: 23.011W
          Main Board +3.3V 3.295 2.524 8.317 2.476
          Main Board +5V 4.975 1.711 8.512 3.289
          Main Board +12V 12.291 0.503 6.182 0.997
          Run C.C. Winstone 2001, +12V-Input, TotalWatts:32.701W
          Main Board +3.3V 3.295 2.689 8.860 2.311
          Main Board +5V 4.951 3.486 17.259 1.514
          Main Board +12V 12.234 0.53 8 6.582 0.962
          You should be OK.
            thanks for the info keeping my fingers crossed.
            NANO-ITX+m1-atx
            512 DDRsodimm
            60g SATA Laptop HD
            4x Apple DVDslot
            digimoto OBDii
            mS GPS
            mini BT keyboard
              acura cl, you a member of acura-cl.com? if not come over and check it out and do you have a first gen or 2nd? and what screen are you using and how are you putting it in, using the bose input? i was thinking of putting the screen where the stero and pocket are .. let me know and take pics of install
              SHOW OFF IN ACURA-CL.com
                wassup,
                yea i'm a member over there too. my username is UMCP.
                i have a 2nd gen cl.
                i saw the screen in the pocket but i think that only that model panasonic that he used fits. it would be cool if u tried to do a vga in there. i didn't want to void my warranty by cutting into the car.
                i bought a lilliput ts and used plexiglass to mount it. the frame is bondoed to the plexiglass.
                it was hard to find a match for the dash color but i got my hands on some black vinyl and its a pretty good match, less sanding for me.
                pics coming soon. i'm soo busy working to pay for this thing.
                NANO-ITX+m1-atx
                512 DDRsodimm
                60g SATA Laptop HD
                4x Apple DVDslot
                digimoto OBDii
                mS GPS
                mini BT keyboard
                  ya i have a first gen and it has a perfiect hole in it for the screen
                  no cutting or anthing
                  do you know any one that has a 1st gen cl with a capputer?
                  thanks
                    i've only seen a couple of 2nd gen TL's with carputers.
                    NANO-ITX+m1-atx
                    512 DDRsodimm
                    60g SATA Laptop HD
                    4x Apple DVDslot
                    digimoto OBDii
                    mS GPS
                    mini BT keyboard
                      Do you think the TC dc / dc convertor will keep the computer on while cranking?
                        nope, the tc dc/dc converter isnt the bit that needs to survive cranking. The carnetix/opus is the bit u need to worry about, and yes, the carnetix and opus both survive cranking.
                        If you use the carnetix 1260 psu, the tc10000 mobo then cranking should not be a problem. I intend on doing the same very soon.
                        www.leoncupra.co.uk
