computer in car help pleas
  • computer in car help pleas
    srry bad engels srry
    i have
    1 computer ibm pentium(r)pro proces 32mbram that i wone make in car
    1 big power problem
    i research and forum's
    i foundt alot not what i need:
    i wone power ma computer with: dc-dc 12v not:dc-ac 220v
    sfx 12-15 powersupply
    and
    opus (only on atx,micro motherboard that i do not have)
    carnetix (m10000 motherboard that i do not have)
    pw60/70+ittps combo ( atx only i do not have that stuff)
    now what do i have:
    ibm coputer with no info off motherboard
    i foundt powersupply in my comp. thats:
    liteon level 3
    input : ac 200-240v/3.5A 50-60hz
    output: dc 120w max
    +5v /20A +12v /8A
    -5v /0.5A -12v /0.5A
    +3.3v/20A +5sb /0.72A
    whit cabels are:
    round and squire hollo pins
    p1 p2 p4 p10 p11
    wonne replace this with dc-dc 12v
    wone that vits in my pc
    pleas help
    What ?
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
      Originally posted by IntellaWorks
      What ?
      Good Question....
      Is your motherboard AT? If you only have 32 MB of RAM chances are it is old enough to be an AT.
      Installed.
      -GPSSecure- - GPS Tracking
        http://world.altavista.com/
        help us out here wierd foreign guy.
          LOL
          Installed.
            this programme were possible but do not translate half useful therefore
              Again I ask: Is your motherboard AT? If you only have 32 MB of RAM chances are it is old enough to be an AT.
              Installed.
                how I can see this
                  how I can see this
                  Whats the model # on your motherboard?
                  Installed.
                    on top off board
                      how I can see this
                      How many plugs from PSU to motherboard? 1 or 2
                      1 = ATX
                      2 = AT
                      ....Yes, I know it has a stupid name, those crazy Japanese!
                        give the guy a brake, it is good enough that he trys .and that he trust us.
                        OK
                        if your mother board has two power conectors with six wires in each from the power supply its most likly a AT .if just one its a newer ATX this will have a conector with 2 rows of 10 pins. the AT is not common any more and you may not find a 12v to 12v supply. you may only be able to use a power inverter. as cost will be much less then building a custom power supply.
                          1 = ATX
                          2 = AT
                          Yep
                          Installed.
                            i see
                            socket 8 amp
                            intelchip pciset
                            thats it
                              on top off board
                              Ya it should be on top of your motherboard.
                              Installed.
