Lilliput Drivers for XP
  • Lilliput Drivers for XP
    I purchased a Lilliput touch screen monitor and tried it at my workplace. It worked fine under that environment using Windows 2000. However, when I used my Neh. M1000 motherboard with XP Pro on it, the drivers do not work for touchscreen. Also, I can not get the properties of the display in XP to go lower than 800 X 600. I tried to change my monitor drivers, and it only will let me install default monitor. I can not get the monitor drivers to work. Can someone please help me?
    Drivers that ship with it for some reason didn't work for me either had to search the forums for other drivers. Try the one's listed here http://www.egalax.com.tw/Download.htm
    Hopefully that will solve your problem
      Thanks Jailer
      Wow! That was pretty quick. Thanks Jailer. I will try it.
        Timing is everything in life
