Compatable cpu heatsink/fan
  • Compatable cpu heatsink/fan
    I need a Heavy Compatible heatsink/fan for this motherboard..
    http://www.syntaxusa.com/catalog/pro...roducts_id=108
    any help?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    would something like this work?
    http://www.directron.com/foxconn370a.html
      yes, probably.
        No, thats for AMD. You would nave no way to attach it.
        It's the cake having/eating thing.
          It will fit. Both the motherboard and the fan are type Socket 370. It'll work just fine. The reason that the cooler says "AMD" is because most people buy either Intel or AMD and they are usually not compatible. As long as the fan is Socket 370 then it will work with that motherboard.
          Progress Bar
          <|---------> 5%
          [See my Worklog] (project on hold...)
            can anyone else confirm that? (no offense jonac)
              Not exactly,
              You will probably have difficulty finding a heatsink for that board. Even if it says is a socket 370, looking at the picture, the socket is missing and the cpu is soldered to the board. Since all heatsinks for socket 370 are designed for attaching on the socket...
              It's hard to advice without the board, but I think you will have to go gheto on this. The original heatsink/fan combo seams to be attached to the board by that 4 little white pegs ( not sure about the correct name ) . My guess is that they are similar enough to vga heatsink attachments, and so you might find some old vga, and steal its heatsink/fan for your board.
              If you find any other way to get a good and even pressure against the cpu, any heatsink will do the job, the one in your link included.
              Brave
              Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
              Status -->
              Lilliput Installed (not indash yet..)
              BraveCar 2.5
                I didn't spot that...! How can they call it socket 370 when there isn't even a socket...!
                http://www.geek.com/glossary/glossary_search.cgi?socket
                Why don't they call it "holes-in-the-circuit-board-370".
                  Not exactly,
                  Brave
                  anybody got suggestions on just how to do that??
                    Do you have the board with you? can you post some close pics of the cpu area with and without the original heatsink ?
                    And the exact distance between the four holes in the board ?
                    Status -->
                    BraveCar 2.5
                      Thermal adhesive. It similar to Arctic Silver (or similar compound) but it's an adhesive. Yes, that means you'd actually be gluing a heatsink to the CPU.
                      Here's an AS adhesive (first hit on by the way...):
                      http://www.arcticsilver.com/arctic_s...l_adhesive.htm
                      And because I know you're reading this, I'll quote the link above:
                      CAUTION!
                      Arctic Silver Thermal Adhesive is a permanent adhesive. Components you attach with
                      Arctic Silver Thermal Adhesive will stay attached forever.
                      There's your warning....
                      How about the Wiki?
                        Alright, the distance, screw to screw is about 3.5cm or 1.5 inch.
                        pics below:
                        http://community.webshots.com/album/169582088CCQJje?347
                          pics below:
                          tks
                          Just to clarify:
                          a-------b
                          c-------d
                          3,5 cm = ad or 3,5 cm = ab
                          why do you want to replace the original one?? and are you replacing just the fan or both ??
                          Status -->
                          BraveCar 2.5
                            it's square, and 3.5 cm equals one side of the square, or 3.5=ab.
                            Whenever i play anything divx in my carputer, it overheats within 10 minutes...
                            So I'm hoping a heavier heatsink/fan will do the job, plus that current one is tiny.
                            I'll probably replace both... but maybe just the fan if that's all I can fit on there
                              Is there no heatsink on that?..
                              Anyway this is what I am running on my EPIA MII 10k. I can't say if it made that much of an improvement or not but I am running my system stable now. Use it everyday.
                              Vantec copper heatsink/fan for vga. With Artic Silver 5 ofcourse.
                              Mine needs to be updated.
