operation Systems
  • operation Systems
    Well, I'm new in this forum and i've built in pcs in many things - but never into a car. so i have to start now
    the first thing i noticed on most pictures, was that nearly everyone uses windows and i just can't understand why...
    is win the best solution for carputers or did just nobody try something else?
    Intel Celeron 365 MHz
    192 MB Ram
    Getting drivers for other OS is the main concern.
      Software, there are more options (especially for GPS) using Windows.
        basically as far as i can see people are not largely familiar with linux, unix etc,etc.... so windows is the easiest and best solution plus as other ppl say it is just simply easier than linux to get into i know of a m8 of mine that now has a winXP disk that he has customised so it will install XP to his own pre-determined specifications without user input ( ie: he literally boots his PC with the disk in the CD rom drive, 2 HRS later his PC has a fully running version of XP to his own spec RUNNING WITHOUT IE, WMP, and with winamp and opera)
        amd k6-2 450
        64 meg ram
        5 gig hdd
        all in an old bit of metal
        all for under £20
        and now a 500watt inverter for £20
        thats £40 in total
        not too bad for a noob
