In Car Puter....
  • In Car Puter....
    Yo,
    I'm trying to setup a computer in my car so I am able to play music off it and use it to play vidoes too. Reading through various posts and other material I've heard many ways to achieve this.
    Basically this is what I'm thinking
    First I'll need to build a little computer ( one of those ITX ones )
    Second need to get a touchscreen monitor
    That the easy bit what I find hard is where is the screen going to go, how is the computer going to be hooked up to the in car speakers and finally how is the puter going to get power.
    Regarding power I know you can either hard wire it to the engine or use a power inverter ( connecting to cig lighter) . However I come a bit stuck when thinking how I will connect the computer to the cars audio system. The car has a basic head unit which can be seen here http://defaced.net/simon/cars/newgol...t/dashkit1.jpg ( note that isn't my car). I'm not sure how you would connect the computer to the cars audio unless there is a special headunit and I'm not too keen on using an fm modulator since I guess the sound would drop
    Thanks would appricate any input.
    ITX > Not my lane. Using mATX.
    TS > Get you a liliput. 7" 16:9 or 8" 4:3. Your choice.
    Speakers > You will need an amp. Even the best soundcard doesn't have any amplification.
    Power: Do NOT hook into the cigerette light outlet unless you wanna possibly blow some fuses. The cig. outlet is not made for a lot of power. Go directly to your battery using 8 gauge wire. Better yet. Ditch the inverter and get an OPUS. An inverter will not be able to kept running when you start your car. The OPUS can and has some extra features such as delayed shutdown and remote start (via ignition).
    Sound: 3.5mm to stereo RCA cable. Take this and plug it in from the soundcard to the HU/amp.
    Derek
    Progress [||-------]
    View my Worklog to see some of my progress.
    Downgraded Progress - Starting with another car... 09/13/06
      Originally posted by Lucky
      Yo,
      try to find out you connection on you radio, if it a new one it normaly has a AUX oor cd changer interface you can use for sound interface from your computer, some radio has defauld disable the function in the setup menu.
      find the manual for the radio.
      You may have a good lock from here with you project...
      Plan for project = 100%
      Part the project. = 100%
      Built...................= 99%
      Finish.................= 99%
      Install ...............= 99% -50%
      Ditail at 4u2n.dk
      Here
        Yo,
        I can recommend the Mini-ITX boards, they use little power and VIA support them very well. In fact they have a section on their web-site just for Car PCs and they keep an eye on our scene
        Best is the Xenarc but it's the most expensive.
        Most people have good experiences with the Lilliput, which is cheaper. I use it and I'd buy another
        Standard, modern car stereo - AUX in adapter (see www.connects2.com)
        Aftermarket or old - See if your head unit has an AUX in, if not get one that does if you want to use a head unit.
        If you want top quality, you can use a car Hi-Fi amplifier direct from the Car PC. Because the amp needs to be 'loud' most of the time, you may find you need a good sound card with low signal to noise for best results with that option.
        If all the above is too expensive or for some reason impossible, you could try a FM modulator to 'tune' in a station on your car stereo. Though most of them are not very good
        If you want near instant on/off like a car stereo - Opus - it's also easy to fit and efficient. Turn the car on, it comes on. Turn the car off, it goes into standby. It survives engine cranks, the other easy options do not.
        You can use a Dc-Dc power supply with a regulator such as the ITPS, which also controls startup/shutdown but no instant on/off or surviving engine cranks
        The last option is an inverter. I can not find anything good to say about them so I'll leave that to someone that likes them.
        No cig lighter connection, go straight to the battery - use a amp wiring kit.
        Is the basic head unit standard? If so a connects2 would do the job
        Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
        Car PC Status: Complete - Undergoing Software Redevelopment
          You say that isn't your car, but is that the same model as your car, if so then take out t5he stereo and the little pocket above it and put the screen there. (the radio can find another home)
          Power two ways.
          1. inverter connected straight to bettery, then your computers mains lead into it.
          2. 12V DC-DC ATX PSU (opus for example) or if you go the itx route there are special itx PSU's. again connect direct to battery.
          Connecting to stereo.
          1. if it has AUX input then dead easy.
          2. As you say FM modulator, loss of quality, depending on your hearing.
          3. replace stereo with one that has AUX input.
          4. go headless, just get an amp which can be installed in the boot and use the touchscreen as controller.
          see above answer
            Thanks for the advice so far.
            If I was going to get the liliput. 7" where do you recon I would have to put it? On the dashboard? Second where can you buy them from? I know they are sold on this site but I live in the UK and I would have to pay loads for shipping probably.
            Secondly what is an OPUS and is it easy to install with the laptop and battery.
            Finally you say you get the 3.5mm to stereo RCA cable to hook the audio to the car - however how would you do this. Since at the moment all the car has is a place where you put the headunit
            edit- Just noticed most posts where most answered - thanks!
            Btw if this helps anyone know what kind of headunit I have it is this - http://caraudiosecurity.com/catalog/...roducts_id+115
              1) Lilliput can be bought from www.cartft.com - from germany - no probalem to import as its in the EU - or get a Xenarc (better) from LinITX.com
              An Opus is a proper Auto PSU - see www.linitx.com for more information. It wires to the battery and to the ACC power
                Show us a picture of your dash.
                Opus is for use withg a standard PC, not laptop.
                If you have that stereo then you are OK as it has the pioneer IP-BUS
                do a on the forum for pioneer IP-BUS and you will find some threads on how to connect to it.
                side note: he is lucky, it's taken until the 8th post for someone to flash the banner
                  Lol
                  Anyway I've done some searching about the IP-BUS for the pioneer. I've seen a few pics and am I right in saying you plug it into the little socket where you normally put the headunit on ( then connect from that to audio input device )
                    is that an audi or a vw
                    passat?
                      Its a VW golf I think
                      Anyway here is a pic
                      http://69.57.174.26/~rory01/CAR/DSCF0069.JPG
                        how bout placing the lilliput 7" where the radio currently is, and running the stereo under it?
                          lol sorry don't understand - where is the radio? :$
                          edit: thinking more it would be more sensible and easier for me to just to get a in-dash monitor. Put it in the free dash space , however I am finding it hard locating websites selling these , and I have tried searching
                          update in-dash touchscreen monitors ( motorized ) seem to cost a bomb
                          . If I was to just get a non touchscreen monitor how would I be able to control the computer
                            search around, people use all sorts of stuff, from little keypads to gyration wireless keyboards mice, and remotes. Search around, whatevers most comfortable for you/and or fits in your ride
                            personaly im going to be using a touchpad from a laptop modded into my armrest, with my lilliput.
                              Ok here's what you do. relocate the head unit, to say the glove compartment, make an extension from the HU to the removeable part and place that under all the controls. then put the monitor where the headunit was and that big space you now have.
                              BTW that's what i am doing with my pioneer headunit. The HU is now in the glove.
