Futur Setup, Is it OK!
  • Futur Setup, Is it OK!
    Here is my futur setup, can somebody chack if it's ok please!?
    Thanx
    My suggestions is to get a Morex/Travla mini-itx case with a 60W PSU inside it, and get yourself a Carnetix CNX-P1260
    Otherwise, get yourself an Opus. Either are the best options on the market, I wouldn't get anything else from experience.
    As for the screen, I personally prefer the Xenarc over the Lilliput, as I have seen/used both, and the Xenarc is much better in both image and build quality.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
      Thanx for the fast reply!
      Thanx for the Power Supply solution, i'll buy an Opus ps. But for the screen I have the Lilliput screen and I have a question concerning that. Can i plug the screen on the Red and Black wires from my old radio. Or I need to buy something.
      Thanx again for the fast reply! Thanx for the Power Supply solution, i'll buy an Opus ps. But for the screen I have the Lilliput screen and I have a question concerning that. Can i plug the screen on the Red and Black wires from my old radio. Or I need to buy something.
        I would (and have) hook up the screen to the 12v wires coming from the power supply, otherwise you will probably get electrical noise on the screen.
        Garry
        www.aimee.cc
          Maybe I'm lucky, but the Lilliput "egg" thing seems to regulate the power pretty well...?
            I've used the "egg", and I have found that it introduced noise onto my screen (wavy lines going up and down it), but the moment I hooked it up to the output from the Opus, it was perfect, no flickering, lines or any brightness modulations at all
            However, your mileage may vary
            Garry
            www.aimee.cc
              Good to know, thanx guys!!
                Yeah that looks like a pretty basic install to me. Also I would not power the screen off the car's power directly without some sort of regulator. I tapped off my Opus.
                Mine needs to be updated.
                  Power Question (Inverter)
                  Just for information, can you Power the Lilliput Monitor with an Inverter, like this setup:
                    You are not powering it from the inverter. You are sending unregulated power to it.
                    Get yourself either an Opus, or a Carnetix CNX-P1260 (if the case you're getting has a 60W DC-DC PSU in it already) and do it right
                    You will thank us later
                    Garry
                    www.aimee.cc
                      In my case if the egg hadn't blown the fuse the second I plugged it in it would have probably caught fire. Don't trust lilliput power eggs.
                        Yeah that diagram does not power the lilliput off any inverter. And why would you want to anyway? Screen wants 12v not , 110vAc
                          Correct me if I'm wrong, but if youre using an inverter, the only ways to power the screen would be directly from car's 12V (as in lyroy pci), plugging into the inverter, or using a 12V line from the PC's power supply. I assume the last method is preferred.
                          My first carPC!
                          MP3/CD player
                          Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
                          Soon to actually find its way into the car!
