Set up Question
  • Set up Question
    I am building a car pc .....
    It seems to me that every one is using intel motherboards and CPU's
    Can any one recomment an AMD Motherboard or is amd even going to work with the OPUS PS 90watt and mATX board?
    Also the 90 watt PS is recommended for ITX boards only.. and then some people are recommending mATX boards for it? Has that been tested to work fine?
    Overall I just need to know if AMD or Intel Works better and ITX or mATX.. I'd rather use mATX, these days prices for ITX are very low.. maybe ITX
    Thanks for the help
    with a 90 watt I would recommend the EPIA 10K it is not just the mother board and proc you have to consider everything that will be connected to the power supply. HD(s), CD/DVD, USB(non externally powered), cards, monitor (if going to be powered by the PS). So what is your total system setup and power requirements?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
      The Opus PSUs are (in my opinion) under-rated in their power output, and often do much more than they say they will (as opposed to desktop PSUs which are grossly over-rated)
      mATX boards should work fine with the Opus, even with desktop drives etc too.
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        Can any one tell me if this ITPS + PW-70a Combo is gonna work like the Opus 90.... Its half of the price and it says its a great solution.... Its in store of the site
          I've got a PW-70A working on a 333Mhz mobo I ripped out of a Micron
          comp.
          It works great. I've even got a 20gb WD HD and a floppy (don't ask) hooked up to it.
          Works great. Haven't had any problems. I've just got to work out my delayed relay to get my power to come on when I start the car. Currently I've rigged a switch to the relay to manually power on the comp.
          Mind Scream out
          Mind Scream out
            The ITPS/PW70a solution works for many but isn't as good a solution as the opus. It will continue to operate in circumstances where the cheaper solution will fail (during crank). The opus may cost more, but many of us (including me) have started with the cheap solution only to need to upgrade to an Opus. I would not only recommend getting an Opus, but getting the 150W version.
            Make sure if you get a Biostar mobo to mention this to Opus as they will need to add a different surface mount component to make sure it'll start up the PC properly.
              Exactly. I've used almost every option, and the Opus/Carnetix are the only options I recommend, because they are the only ones that have worked for me.
              Garry
              www.aimee.cc
