In response to everyone asking about their carpcs
  • In response to everyone asking about their carpcs
    FIRST OFF! Don't let this deter you from making a carpc because the prices seem high, this is a very nice system, and many of these componenets could be easily swapped for cheaper ones, if thats what you wanted. I posted these items, because they were the best of what i could get for my price range, and i thought they were reasonably priced.
    There are 100 different ways you can take to make a carPC, this is the one i chose
    Here are Great components for the money, and a decent explanation of stuff, look here if your just thinking about setting up a carpc.
    bottom for pricing totals.
    mATX motherboard, and 2.7ghz Celeron - 120$
    Includes Chaintech 9VIF1 VIA Socket 478 microATX Motherboard and Celeron 2.7ghz
    Motherboard has onboard video, audio, usb ps/2, serial, 10/100 and ps/2.
    http://www.tigerdirect.com/applications/Se...6794&CatId=1232
    Motherboard
    Processor
    Spire CoolWave CPU Cooler For Intel CPUS - 25$
    'low profile ~(50mm high)' for celeron 2.8ghz 'sink 'n fan, 2500-4200 rpm
    http://www.newegg.com/app/ViewProductDesc....-151-116&depa=1
    Heatsink And Fan
    AHANIX Silver/Blue Micro ATX Desktop With LCD Display -26$
    Great Micro ATX case, built in fan/temp monitor LCD monitor on case
    http://www.newegg.com/app/ViewProductDesc....-126-141&depa=0
    Case
    Powmax 60mm Case fan (suggested aux fans) - 4$
    Quiet, Fast, 60mm, fit the case. 4200 rpms. 12v, Suggested 2!
    http://www.newegg.com/app/ViewProductDesc....-886-001&depa=1
    60mm Fan
    Zalman NP(Noise Prevention)Heatpipe HDD Cooler -27$
    Great hard drive silencer, cooler, and mounting unit. Its perfect for mounting in your vehicle, it has rubber stoppers for shock absorbtion
    http://www.newegg.com/app/ViewProductDesc....-118-215&depa=1
    Hard Drive Mounting Bracket/Silencer/Cooler
    Power Supplies, two main categories here:
    DC - DC (more expensive, more efficeint, lower power, less noise, cleaner)
    Definiton: DC-DC, DC=Direct current, what batteries ouput, and computers use. A DC-DC regulated power supply, simply connects to a car battery, and powers your computer, it makes sure you componets wont get fried.
    Opus Solutions, makes a wide variety of these, from 60watt to 150watt. The 150watt retails at 200$, but has some great features, shutdown controller for your PC, pertects against voltage spikes, survives crank, autoshutdowns on lower voltage, has a 20amp automotive blade fuse. It also comes in a case, and connects directly to your battery.(DC-DC car 150w) +200$
    DC-AC, AC-DC
    DC-AC is only 90% efficent at wattages around 150 (continous), same for AC-DC, meaningly you'll lose 20% power to noise and heat. However this option is much cheaper, and can hit way higher wattages. However you cannot run this through crank (without risking damage to your components) and you'll have to make sure these are well ventilated. While you could get a 500 watt computer psu and 500 continous inverter for 40$.
    CAUTION: The efficieny of an inverter, and of a AC-DC psu, will decrease greatly as the wattage increases! That means that 90% is ideal for an inverter at 150 watts, it will most likely not achieve this, and no one needs that little power. Meaning more realisticly it would be 70 and 70 tops
    Use Ebay/PriceWatch/Newegg/Tigerdirect for:
    HardDrive: 160gb Samsung 5400 RPM - 99$, 80gbs - less than 60$ (new)
    Mini USB Keyboard - 20$ (new)
    Ram: 512mb from ebay, less than 40$ (used)
    All Software, varies heavily.
    Other suggestions, all peripherals are generaly chosen at users discretion, whatever feels best to you, although inparticular, Wireless, flat and small things are generaly best for vehicles.
    Monitors are also generaly tailored around your needs, (although i do suggest the 7" Lilliput VGA Touchscreen 300$).
    LILLIPUT shipped- 300$,
    sacrifice quaility - rca monitor about 150$
    When purchasing a HardDrive, make sure to get a 5400rpm!, its the slowest a HD can spin, and the slower the better in an automotive environment (less chance of damage, and much cheaper). OEM 160gb 5400 rpm HD goes for 99$ retail.
    Wireless Connection, 802.11g PCI card, or 802.11b with a signal extender, (2.4 to 5.5db aprox.) from radioshack cost 24$
    Small USB microphones, good one, 50$
    Gps 'mice', are also a nice addition - 40$ with shipping
    Cameras (webcam) - 35$
    Complete Systems
    Cheap - 500$
    What it includes:
    Case, Motherboard, Proccesor, Mounting Unit, Fans, HD, Ram, Keyboard, Inveter, AC PSU, RCA Monitor
    Mid - 660$
    What it includes:
    Case, Motherboard, Proccesor, Mounting Unit, Fans, HD, Ram, Keyboard, DC-DC psu, Rca Monitor
    High - 750$
    What it includes:
    Case, Motherboard, Proccesor, Mounting Unit, Fans, HD, Ram, Keyboard, DC-DC psu, Lilliput Touchscreen Monitor
    BareBones: 202$
    (which includes, case, motherboard, processor, mountning unit, overly efficeint fans) (120+25+26+4+27)
    With Input Devices, HardDrive, Ram: 322$
    (which includes, case, motherboard, processor, mountning unit, overly efficeint fans, traveling keyboard, HD, 512mb RAM) (120+25+26+4+27+20+60+40)
    before you respond, and say something stupid,
    I had all of this info at hand, seeing as i just orderd most of the components, and this was copied from another forum
    OK LET'S TRY THIS AGAIN.
    While RogerWilco may be a postwhore ( Well definately) there is no
    reason to flame him when he is trying to be helpful. If there is incorrect
    or inaccurate information in the post, then correct him with tact and
    common sense.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      Understood. But, when you don't know what the **** you are talking about, you have to one to blame but yourself when you get flamed.
      http://www.mp3car.com/vbulletin/show...503#post257503
      clearly he is now an auto mechanic as well. Stuff like this deserves to have the **** flamed out of it.
        Well Motorcity, in that thread, he is right. If you remove the air vents, you
        will usually seal them up instead of letting them blow air out in your dash.
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          If you say so. The few (very few) dash mods I have done, as well as the shops in Detroit do, I (they) re-direct the air flow to avoid excess air going out the remaining vents. Not just seal them off. Noise is usually a concern to people when they have the heat or a/c cranked up, and blocking off a vent or 2 completely will increase outlet air pressure at the remaining vents, creating added and unwanted noise. My point was, that he seems to have a lot of knowledge about a lot of subjects for only 17 yrs. old. I am sure he has read a lot, but in reality, hands on experience speaks for itself, and one should speak from experience, not just quote text and verse. At his age, he should be out chasing girls and trying to buy beer with a fake ID, not trying to be Consumer's Report, AutoWeek, PC World, and Custom Car rolled up into one.
            Well we are kind of off topic but I want to know (I'll fix it later)
            Where do you re-direct it to ? Because I may have to remove my vents.
            And I was just going to seal them like a lot of people. But If you have any
            ideas ... ?
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              You can redirect the air to the feet, just use some flex pipe and make a outlet at the bottom of the dash.
              Installed
              Asus A7N8X-VM - AMD Mobile Athlon 2400
              512 Ram - 60GB HD - Opus 150w
              Lilliput 7" - Rikaline 6010
              [00000000000001100010-] 98% Completed
              Check Out My Install!!!
                hands on experience speaks for itself, and one should speak from experience.
                Word. Bird.
                The Ultimate CBCC?? (Clean Black Car Club)
                Click here for the Truth
                  Exactly. or, depending on the car, if the fresh air intake tubes are accessable, flex tube 'em into there. Cars also have what are called body vents, which would exhaust this unused air flow outside the car. They look similar to the body vents you see on the B pillars when you open your door, and look below the striker. these vents exhaust to outside air, and usually are used to bring in fresh air when the heat/ac unit is off, and to equalize inside air pressure when you close a door when the windows are up.
                    Originally posted by Enforcer
                    Boy, this thread sure has changed since the last time I saw.
                    I kind of liked it the way it was originally
                    AtmosUSA.biz, E-Cig Mods
                    "A great smoking alternative"
                      Would it not be good to let some air through? to the back of the display, to cool it some?
                      In the winter, when using heat,...the heat would not blow through the top vents? but through the floor vents, right?
                        Yes and no. The heat and a/c use the same air ducts. Most cars have a panel select for the vent location, meaning the driver can switch between top of dash,(defrost) floor or panel (dash), which would be the area of discussion. If you were to only use the floor, or top of dash in the winter when you have the heat on, then sure, leave the dash vent partially open. But, what if say, on one of those nasty cold mornings you want that nice toasty warm air blowing out the dash vents to warm your hands? then, you would have hot air blowing on the back of your lcd, which already generates more than enough heat.
                        Now, summer time, with the a/c blowing, this would be ideal as you now have a free, effective cooling method for that hot screen.
                        It really becomes a toss up, but in my opinion, blocking off the unused vents and re-directing them elsewhere would probably serve best, since you won't limit yourself when it comes to use of any of the vent choices for heat or a/c.
                        Hope this makes sense.
