a few (newb) questions, as far as wiring and power, etc
  • a few (newb) questions, as far as wiring and power, etc
    mkay, when it comes to electricty, i totally suck and could probably use to a good URL to read up on basics, so if anyone could point me in the right direction on that, much appreciated.
    on to the real purpose for the post.
    I've got an EPIA-M 600mhz board/proc combo. an 80gb WD 3.5in. hard drive, and a mitsumi 8x dvd drive.
    soon, i plan on purchasing a lilliput 7" touchscreen tft display.
    as far as power supply, i have the 200w snap in (no wire) power supply for this board as well as the ITPS regulator.
    now I have the wiring diagram that was supplied with the itps reg. and the psu, no problem there (as far as i can tell ;x)
    now, i'm almost definately positive that the psu will power the hdd and the dvdrom no problem, so thats not really an issue, my real issue is running the power for the lilliput screen, i just saw a diagram that shows it being run off the powersupply, and i'm not really sure if i could, or if i wanted, to do that - i was planning on drawing from the cigarette lighter lead, or something like that, like i said - i'm no electrician ;P
    any suggestions as far as powering this screen?
    also, any reading material you guys could suggest would be much appreciated, and - what would the the max load on my psu, in your opinion?
    thanks a lot
    Well i ran mine off my 120w from ebay. (but i didnt do that long because i was gettin noise from it through my speakers, but i think it was just because i didnt ground my motherboard). As for how you should power it I dont quite know yet I have few problems that ima work out. I went out tonight and on my way home i ran into these problems again. Ima put back on my psu tomorrow and see if that helps.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
      any others? :\
        Go visit www.the12volt.com. Lots of car related stuff there.
        Derek
        Progress [||-------]
        View my Worklog to see some of my progress.
        Downgraded Progress - Starting with another car... 09/13/06
          http://www.bcae1.com/
          Leo
          http://www.talkaudio.co.uk
          A million people can't be wrong, right?
          Well... unless they're all from the red states...
            Originally posted by LeoTheHamster
            Another good one. Should have taken a look at my Favorites. Both 12Volt.com and BCAE are in there plus a few fiberglass sites.
            Derek
              awesome, thanks guys
                I hooked my lillput back on my PW70A 120watt and it was worse. I can only boot my computer with truck on and it has shut off a few times. I dont recomend puttin it on your psu. Unless you had an opus i suppose.
                I GIVE FREE HUGS!
                Buy Sell or Trade
                Thank you
                Forex
                  I seemed to miss the fact that you needed information about hooking up your screen to your PSU. (TIP: You can run more than just your screen. I am running my screen, USB Hub, and SoundBlaster Extigy.) I highly recommend getting a multimeter. It has been used a many occasions during my carputer/stereo installation. Even the cheap $20 small digital one from RadioShack works great. That's what I use.
                  Cut the plug off from the 12VDC cigerette light plug. Determine which of the wires are positive and negative. Extend the wire attaching the positive wire to the yellow power wire for the drives and the negative to the black wire for the drives.
                  Better yet. Take your screen into RadioShack. They can determine what size Adapt-a-Plug you need (I think I used N Size) and then simply get a 15-foot Adapt-a-Plug (similiar to THIS but they have it available longer and without the extra connector. The 10 foot was too short which I still need to extend.).
                  Derek
                    Originally posted by d_sellers1
                    Better yet. Take your screen into RadioShack. They can determine what size Adapt-a-Plug you need (I think I used N Size) and then simply get a 15-foot Adapt-a-Plug (similiar to THIS but they have it available longer and without the extra connector. The 10 foot was too short which I still need to extend.).k
                    Can you please make this more clear? Leave the 12V car lighter plug in tact (including the "egg") and extend it to the PSU, then make my own molex plug using the + as 12v [yellow molex] and - as ground [black molex]. Did I get that right?
                    http://www.cardomain.com/id/seanklsc
                      You are correct however I have read posts stating that the 'egg' tends to burn out or die. If you don't want to buy anything then I would cut between the plug (to the screen) and the egg and wire as you described above.
                      Since I did not want to cut the original powersupply, I went to RadioShack and bought the following:
                      Adaptaplug N - $4.99
                      6 Ft. Adaptaplug Extension Cable - $5.49 This cable has two female connectors for the adaptaplugs. I cut it in half and used on side for the screen and the other for my SB Extigy.
                      For best results get a Molex plug so you can simply plug it up to your power supply. You can also find them at RadioShack but I'm not having any luck finding them on the website. Don't forget to look up the Lilliput Auto Turn-on mod for the Lilliput.
                      Derek
                        I checked that out, but it is wayy too hard for me. I'd rather turn my monitor on manually than fry it with some silly mod.
                          I'm actually going to have a friend supervise me/assist me/do it for me.... (pick one). If you can get someone to do the soldering for you, I would think that would be a good improvment to your system. You computer starts up and the screen will also turn on.
                          Derek
