power up problems...
  • power up problems...
    well i went through, installed everything, and tried to power up, and i get nothing... i want to make sure of a few things w/ you guys before i go getting too ****ed off..
    on the ignition of an opus, blue wire, can i just hook that up to the same wire i would hook into a turn on lead of an amp??
    is there a way to tell if the opus is running but the mobo not turning on??
    how long should i have to wait after i turn the car on for the mobo to start running w/ an opus 90?
    hope i can get some help here, im pretty frustrated righ tnow, and i am sure some of you know what i am talking about along these frustration lines...
    thanks in advance...
    Pull the main OPUS fuse, wait 30 minutes, then try to plug it back in.
    Quick! To the Popemobile!
