Turn off check disk in XP
  • Turn off check disk in XP
    I've finally discovered how to keep XP from running check disk on startup after a non-graceful shutdown (all you fellow POS ITPS owners know what I'm talkin about). This is a registry modification:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager
    REG_MULTI_SZ: BootExecute=""
    with the autocheck autochk * removed you'll no longer be bothered with check disk.
    enjoy
    nice find, where did you find it?
    [COLOR=Navy][SIZE=1][FONT=Comic Sans MS]Tektility
      actually I found it myself while trying out a regedit I found googling that didn't work. I forget the key but it was a DWORD that basically modified the time you have to hit a key to skip the check disk and the site claimed setting it to 0 disabled check disk...nope just eliminated my chance to skip the check. It just happened to be in the same location as the BootExecute key. I figured what the hell, I'll delete the contents and see what happens
        S.M.R.T.
        good job!
          enjoy
          It's your data....
          How about the Wiki?
            if you have a ntfs filesystem.. it shouldn't do a check anyway since its a journled filesystem.. or so i think
            '98 Explorer Sport
            80% done
              Originally posted by DarquePervert
              It's your data....
              sure is I didn't say its a good thing to do but it can be done if you wish to do so
