Power Consumption For P4 MB?
  • Power Consumption For P4 MB?
    As a newbie forgive me if this question asked before but I need feedback from actual configurations.
    I have Opus 150W Power Supply. For some reasons I am looking to purchase P4 based MB and Celeron or P4 CPU. It's hard to find mini-ITX boards in Turkey. Since Opus 150W Power Supply has P4 connector, it means only for mini-ITX P4 boards or enough to power micro ATX mainboards (ie Intel 845 chipset with Celeron 2.4 CPU)?
    Anyone has a configuration like this?
    If yes any startup difficulties?
    As I made some measurements for Power Consumption during startup I saw consumption increases at least 2 times than standby.
    Also I asked to some MB manufacturer they told me that required power supply for mentioned MB and CPU is min 200W.
    Also I checked this power simulator:
    http://www.epiacenter.com/powersim/e...ulator_tc.html
    [email protected] option is for mini-ITX board only?
    According to pc power and cooling:
    Component Requirement Line(s) Used
    AGP Video Card 30 – 50W +3.3V
    Average PCI Card 5 – 10W +5V
    10/100 NIC 4W +3.3V
    SCSI Controller PCI Card 20W +3.3V and +5V
    Floppy Drive 5W +5V
    CD-ROM 10 – 25W +5V and +12V
    DVD-ROM 10 – 25W +5V and +12V
    CD-RW 10 – 25W +5V and +12V
    7200rpm IDE Hard Drive 5 – 20W +5V and +12V
    10,000rpm SCSI Drive 10 – 40W +5V and +12V
    Case/CPU Fans 3W (ea.) +12V
    Motherboard (w/o CPU or RAM) 25 – 40W +3.3V and +5V
    RAM 8W per 128MB +3.3V
    Pentium III Processor 38W +5V
    Pentium 4 Processor 70W +12V
    AMD Athlon Processor 70W +12V
    For overall power supply wattage, add the requirement for each device in your system, then multiply by 1.8. (The multiplier takes into account that today’s systems draw disproportionally on the +12V output. Furthermore, power supplies are more efficient and reliable when loaded to 30% - 70% of maximum capacity.)
    I'm confused.....
    Depends on the hardware you use. The Opus is enough to power your board and chip for sure.
    I'm using a desktop power supply, 140watt. I'm powering 2 desktop hard drives, desktop cd-rom, PSone screen, P4 2.0, and USB to IDE.
    Tidder
    Try RevFE
      try this calculator. they are only guidelines but close is probably OK
      http://www.jscustompcs.com/power_supply/
      TruckinMP3
      Read the FAQ!
        Thanks you gave me a hint
        Of course depends on the hardware and depends on software you run. With 140W PSU do you have problems at startup or running software like Office applications?
          No probs at startup, no probs running my software, CDex (ripping soft), or even watching DivX movies and stuff. Burning CD's, no problem either. It's been running pretty good for quite a while. Oh, and I forgot to mention, I also have a Geforce4 MX440 8x AGP card in there too.
          Edit: Also have USB wireless network doober. And sometimes USB keyboard.
          Tidder
          Try RevFE
