will frodoplayer run on windows 98?
  • will frodoplayer run on windows 98?
    like it says, im trying to use this crappy old computer until i get something better
    i tried installing and it says required .DLL, GDIPLUS.DLL was not found... frodoDVD worked fine, anyone have any suggestions?
      That's the .net framework. You need it.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        .net framework? where do i get that?
          http://support.microsoft.com/default...b;en-us;308488
          Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
          GET PAID TO SURF THE INTERNET
            actually, you just need that dll
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
              got the program running but everytime it loads it just freezes and crashes. might be because of crappy win 98
                Didn't think .net framework installed on 98
                AtmosUSA.biz, E-Cig Mods
                "A great smoking alternative"
                  Yes it does. I had same problem at first. windows update fixed all.
                    yeah saw .net in the optional updates when i installed Win98se for a friend the other day. 98 is nice and quick but I don't think i could ever go back after using XP
                    edit: how crappy is your pc?
                      its a p3 600 with like 128 megs of ram
                        stick some more ram in it and it should do just fine
                        I am guessing that it runs on strait SD ram, have not check SD prices recently but they used to be rediculously cheap with 512 I am sure it would run 2000/xp with no problem, 256 or more should work.
                        My desktop at work is a P3 700 i think, with 256, running 2000. It is slower then i would like booting up, but once it is going it runs like a champ.
                        My Install
                        Software:
                        CFiG v1
                        iGuidance Plugin for CF
                        CarShell
                        Working shell for a CarPC
                        StopWatch
                        StopWatch plugin remade for centrafuse RC1
                          wow i have been playin with frodoplayer a bit on my good PC, very nice program, im not using it on a touchscreen yet but i can imagine that it works great. Is there anything additional that needs to be done aside from just installing frodoplayer and the touchscreen software to set it up?
                            windows 98 update?
