will usb sound card help reduce noise?
  • will usb sound card help reduce noise?
    other than the better sound output, will a sound card, lets say this:
    Creative Labs USB2.0 Sound Card
    remove unwanted noise?
    bump
      Depends on why the noise is there.... if you have a bad ground (the most common cause of noise) No it will not.
      TruckinMP3
      Read the FAQ!
        The ultimate way to reduce noise is to run optical S/PDIF out to an external DAC or surround processor.
          you have a point there,
          but lets be serious... unless i will be living in my car, theres no way im going to spend that much more money to build my car computer.
          its so hard getting cheap stuff here in canada. bull**** fudge tax and duties
          die!!!! (not you)
            Of course, that's effectively what a USB sound card does for you -- albeit with a different digital protocol.
            2004 4runner
              you took the words right out of my mouth man.
              Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
              Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
              S2000 Carputer
