What AMP fuse to use?
  • What AMP fuse to use?
    I'm in the final stages of buildign the carputer, I have one question.
    So i'm connect the battery directly to the inverter then to the ocmputer, inorder to protect my circuit i'll have to put a fuse in between the inverter and battery???
    if the above is true, then how do i know what amperage to use? Someone provide me with a formula?
    Well, Hopefully the inverter is fused itself, see if it has a fuse in it. If it does, it's still a good idea to put one right by the battery post, to shutoff that whole wire in case it were to short to ground. In that case, just use the same amperage fuse that the inverter already has in it. If it doesn't, then see if the inverter has a rating on it, look for Max. Input Wattage or Max Input Amperage. If no input levels are given, then there should at least be an output wattage on the inverter (i.e. 200 watt inverter). I would add 10% to compensate for the power being consumed in the inverter (turned into heat -- this would give us 220 watts in my example) Now that you have a gross input wattage, simply divide by 12 to find amperage. So for a 200 watt inverter, you should assume that input current will be just under 20A. Thus, a 20 amp fuse should suffice. I would personally use a 25A fuse, it will leave a little room on the circuit if you tap something in later on, but still will protect in case of a short. By the way, remember that you will have about 20 amps running through this wire, be sure to use a proper size wire for the job (at least 8 gauge, and in any run over 6 or 8 feet i would use 4 gauge)
      My 1500 watt inverter recomends a circuit braker rather than a fuse. You may want to consider that. Make sure you compensate for surge power. For example, my inverter is 1500 watts but the surge is 3000 watts. There is a %10 power loss also. So It's possible for mine to draw 3,300 watts which converts to 275 amps. So I would use a 300 amp fuse or circuit breaker. I used the cheap one but should have gotten the water proof one.
      Fuse holder
      Fuses
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      8" Lilliput touch screen
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        thanks for the excellent advice guys!
        so what if i use a resister with a value too high, say i put a 30 amp fuse in instead of a 20 amp fuse? what' would happen then?
        I'm guessing there'll be less current passing through the wire?
        and fuses comes in a whole variety of shapes and sizes, are there any difference between them?
          30 amp fuse instead of a 20 will make no difference in the circuit....the fuses have no noticable resistance. You are only trying to use as small a fuse as possible, so that is something goes wrong <short circuit>, the fuse will blow before wires melt or something catches fire. If the entire circuit is run with good wire, there's nothing wrong with a 30 or even 50 or 70 amp fuse. As long as all the wires can support that amperage without catching fire. A 30 amp fuse will be fine for your application, just remember the 8 gauge wire, and a good matching ground wire.
            how many watts is your inverter? do essentially what dallas said to find out the amperage that you're pulling, and use this chart:
            http://www.crutchfield.com/S-uSUSbPv...ble_gauge.html
            to figure out what size wire to use.
            put the fuse within 18" of the battery. the closer, the better.
            by resister do you mean fuse? if you use a larger fuse, more amperage will be able to pass through the wire before it pops. so, for the purpose of this discussion, you put a 150 amp fuse on a 10 foot piece of 12 gauge wire. the 12 gauge wire will only be able to handle up to (using the above chart) 20 amps. if there is a short in the wire, as in it touches the car chassis without mcuh resistance, the wire will heat up to a point where the plastic will start to melt, and eventually start a fire. if you had a 20 amp fuse on there, it probably would have popped within 5 seconds, thus saving your life and preventing a car fire.
            point is, use a big enough fuse for the inverter, but dont use a fuse thats too big for the wire. if the inverter needs a larger fuse than the wire can handle, use a thicker gauge wire.
            rebuilding carpc... kinda..
              Nice chart but damn, they never go up high enough for my 3000 watt inverter and amps that im running on the same line. I hope my 1/0 wire is good enough. Im only running it about 5 feet. Anyone know of another chart?
              2.4 celeron
              150 watt OPUS
              micro atx
              xp pro
              tv/radio tuner card
              audigy
              Dual monitor Radeon
              802.11G Mimo
              xm pcr
              dvd
              gps
              IGuidance
              dual optimas
              battery isolator
              15" screen
              My Truck
                3000 watts, max, right? you realise the usual house circuit is only 15-20 amps....which is at most 2000 watts. this is why space heaters only go up to 1500 watts....
                  How many alternators do you have in your truck? That inverter will suck up to 250 amps.
                    by this, if i get a 400w inverter my fuse should be 40amps or less?
                    i'm running wire in a 4runner (SUV) to front seat area, approx 6' would do...
                    i could use 10g, but if i use 8 or less, is there a problem then?
                    i figure just incase i get a 750w inverter in the future
                    [4Runna]
                    next - wifi
                      Thanks fantomas. U laid out what I was trying to say. Big enough to handle the load, but small enough to protect the wiring. By the way....ALL wires attached to that circuit should technically be sized to handle the fuse. Thus, don't tap in a 20 gauge wire just to run to one little light bulb somewhere. If that lil wire shorts out, it could catch fire before the fuse blows. So, as Fantomas said, the fuse should be large enough to handle your loads, but small enough to protect every wire in the circuit. And, of course, as close to the battery terminal as possible.
                        You would have to put an additioal in-line fuse on the small bulb wire to protect it. I have a main fuse at the battery. That 1/0 wire goes to a fused distribution block with smaller fuses.
                        2.4 celeron
                        150 watt OPUS
                        micro atx
                        xp pro
                        tv/radio tuner card
                        audigy
                        Dual monitor Radeon
                        802.11G Mimo
                        xm pcr
                        dvd
                        gps
                        IGuidance
                        dual optimas
                        battery isolator
                        15" screen
                        My Truck
                          A 40 amp fuse would work fine. If you plan on using a 750 watt inverter in the future, I would use 6 gauge wire. There will be no problem in using a larger wire. It's just more $$$.
                          2.4 celeron
                          150 watt OPUS
                          micro atx
                          xp pro
                          tv/radio tuner card
                          audigy
                          Dual monitor Radeon
                          802.11G Mimo
                          xm pcr
                          dvd
                          gps
                          IGuidance
                          dual optimas
                          battery isolator
                          15" screen
                          My Truck
                            Yes that is 3000 surge, but for sizing wire and fuses you need to make sure you can accomidate that. Its 1500 watts normal. 20 amps * 120 volts is 2400 watts. But besides that, my inverter has 2 outlets.
                            2.4 celeron
                            150 watt OPUS
                            micro atx
                            xp pro
                            tv/radio tuner card
                            audigy
                            Dual monitor Radeon
                            802.11G Mimo
                            xm pcr
                            dvd
                            gps
                            IGuidance
                            dual optimas
                            battery isolator
                            15" screen
                            My Truck
                              I have one 130 amp alternator. I dont plan on using that many watts though. I'm only running the computer, stereo and some screens. But I got a good deal on the inverter and it's nice to know that if you ever need it, its there, at least until you kill your battery which would be pretty quick at 275 amps.
                              2.4 celeron
                              150 watt OPUS
                              micro atx
                              xp pro
                              tv/radio tuner card
                              audigy
                              Dual monitor Radeon
                              802.11G Mimo
                              xm pcr
                              dvd
                              gps
                              IGuidance
                              dual optimas
                              battery isolator
                              15" screen
                              My Truck
