CarPC in Jeep Cherokee
  • CarPC in Jeep Cherokee
    I am considering installing a carpc in my 2001 Jeep Grand Cherokee. I'm quite adept at using computers, but not so much at building them. I really don't know very much about cars either. I'm fairly good at things involving electronics and mechanics, so i'm confident that I could handle the wiring and such.
    But I haven't been able to find a very good "guide" or "tutorial" on building a carpc. I've been looking through this forum for a while, and most of you seem to know what you're talking about. I was hoping some of you could give me some ideas as to how I could go about setting up the PC in my car and the basic supplies needed.
    Here are a couple of pictures of where I would like to install the screen. I haven't taken the dash out yet, but ideally, I would like to install the computer behind the screen (space permitting) and a DVD player perhaps in the center console.
    Also, if anyone has installed a carpc in a Jeep or similar car, I would be glad to hear any ideas you have/troubles you came across/etc.
    Thank you all for your help, sorry if this post is a little long.
    hello felll Jeep owner.
    I have a 99 Grand Cherokee, and i have been planning a carputer for a while.
    Their jsut isn't enough room to place a molded 7inch screeen or a computer inside the dash.
    What i plan to do is grab an in-dash lcd touchscreen like so
    http://www.digitalww.com/DWW-7VGA.htm
    Now the stock headunit size is 1.5 din. So that will take up 1 din of it, the other 1/2 din i think im gonna put a DVD player right their so i dont have to reach anywhere to put one in.
    Now i will have the computer under the rear seat, in one of the little cases(on ebay if you type in mini itx their is a nice white or black case) about 80 bucks. In that i will have a 1ghz c3, 512, 60gig and so.
    Under the rear seat their is alot of room, if you go to www.wjjeeps.com then audio upgrade and look for the amp install. If you cut the stupid sheet metal that serves no purpose, their is ample room.
    It will go under their, and i will run a usb hub up to the front, and usb and power for hte dvd and screen.
    For input i was thinkin a IR reciever something simple.
    Power i will be doinga M1-ATX from this site.
    Alot of people have done some with the Grand Cherokee, do a search here, you will see, another guy is doing one with teh new mac, and will be molding a screen in.
      duger, can you post some pics of what it looks like behind the stock stereo? How much space is behind there?
        this is what i found for a pic
        http://www.wjjeeps.com/radio_remove3.jpg
        not alot of room
          You and I are in the same boat. Iím attempting to do the same thing. Iíve been researching this a lot in my spare time. In my recent on and around these boards I've managed to come across these links. Hope these help you.
          1.) this is my favorite install here. Looks like this person decided to lose the center vents along with the factory radio. In their place a very well done (I must say) custom made fiberglass / bondo LCD bezel. (this is what Iím hoping to duplicate with an 8 inch TS LCD.)
          2.) here. is another install. This person took slightly different approach. Also choosing to loose the center vents, but keeping the headunit intact and bulding in a ďpull-outĒ touch screen. (Iím personally not to fond of this install -- but hey, it works. )
          3.) here. is yet another install. I like the idea behind thisÖ but I think it needed some work.
          I had an idea to do something like this instead. but the fact that the TS is too far away to reach comfortably while driving would cause problems later on.
          Here are some basic Cherokee installs. These might give you some ideas as well.
          1.) Link 1
          2.) Link 2
          Also, do a search on the boards for "Jeep Cherokee" and see what you find. There are a couple of threads with older installs for some ideas as well. Just takes a little time to read through all the threads is all.
          (Edit: Spelling)
            Knubile,
            take a look at this threadÖ.
            http://www.mp3car.com/vbulletin/showthread.php?t=41383 for a picture of what is behind the radio and trim.
              Anyone have pictures of a screen inside a regular non-Grand Cherokee?? That's the biggest part that's holding my install up! Dunno where to put the screen!
                I think the best way is to fabricate your own dash, IE make it taller. The Lilliput was too big for my dash too so I made my dash bigger. It too A LOT of time, but surely u'll be satisfied with the result if u did it right
                  If you wanted to mess with the AC/heater controls and the vent below it, you could shift them around to gain enough space to mount the screen there.
                  http://www.experimentalinsanity.com/case/nova/wire1.jpg
                    I am having the same Issue I have a 2004 Jeep Liberty the dash isn't big enough to put the screen where I want it but I am working on it
                      OH GOD!!!!
                      that's one of the most hideous things I think I have seen!
                      Sorry if that person is on here....but DAMN!
                      Jan Bennett
                        thanks all of you for your replies. knubile, i have yet to actually remove the stock stereo, so i don't know how much space is back there. probably not enough to install the computer, but it's possible. i'm having to hold off the project for a while, mainly because the jeep is not my car. my car is an old crappy '94 ford windstar, but my dad recently got hit while driving it. we don't know if it's totaled yet. since it's only worth around $2000, it's likely that it is totaled. if so, the jeep will probably become mine and my parents will get a new(er) van. if not, we'll only fix enough to keep my van drivable, and then i'd have to do the installation in it. i'm not planning as much for this, because i'm hoping the van is totaled
                        Red GTi VR6, i agree. they could have at least made it a little...cleaner?
                        also, i love your install. just beautiful. i've been following that thread for near a week, it's quite impressive. glad to see someone who loves their work as much as you.
                        thanks again for all the ideas and help. i'll post an update soon, when i find out what's going to happen. sorry for the long-ish post.
                          Just FYI.. #1 is me.. =)
                          www.i-hacked.com Hardware hacking articles
                            I think, unfortunatly, for a regular Cherokee, I may have to go the route of a gooseneck coming off the change tray on the bottom. Maybe even take out the ashtray (below the center vent) and bolt a smaller gooseneck or something. I really really don't want to loose my HU, HVAC controls, nor the only center vent. *sigh*
