Does anyone have a complete wiring diagram?
  • Does anyone have a complete wiring diagram?
    Does anyone have a complete wiring diagram for a carputer?
    I am a little confused on where to start.
    I am not sure on getting the power to the carputer.
    I would like to know how to get the power to the carputer , starting from the battery and ending at the pc.
    I have been searching and have ended with no luck.
    J
    search the show off your projects forum, there are diagrams in there and also more than enough pictures to allow you to visualise yourself, half the fun is figuring out the hard stuff yourself....wiring is actually the easiest....
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
      You need a piece of hosepipe, just make sure it's downhill to the pc.
      Laidback
      The ultimate CarPC - Wow!
        It's simialr to wiring up an amplifier.
        basically use GOOD ENOUGH wire (like 20amp)
        BATTERY ===[fuse]====|cabin=====================CARPC
        ignition yellow wire--------------
        ground=====================
        HEAD UNIT ~~~~~~~~~~~~~~~audio wire
        make sure it's all fused.
        If you buy an Opus PSU you get a wiring diagram with it.
        Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
        Car PC Status: Complete - Undergoing Software Redevelopment
          Yeah I know im a sucker doing all you're work for you...
          You should lurve this...
          http://www.carnetix.com/applications...ion_detail.htm
          Carnetix do PSUs and have wiring diagrams on their website!!
