Questions about extending wires from Xenarc
  • Questions about extending wires from Xenarc
    Hey guys, can someone refer me to a USB extension and VGA extension cable. As it is now, I dont really have access to the Xenarc screen because its in my dash and to access that would be a serious pain. Whats a good VGA extension cable with no loss in quality of picture as well as good effective extender for the USB for the touchscreen.
    Also Im assuming any 2.5" extender would work for the sound? For that, I can probably get access to my RCA cables if need be but rather not if I dont have to.
    Hopefully someone can give me some suggestions.
    Thanks!
    for the vga cable to to find a old cable that is removable from a old svga monitor and use a male-male connector to join the cablesand yes any 2.5mm stero cable extender should work but are you use you arn't using 3.5mm
      Yeah sorry, the 3.5" is correct. Sorry I mistyped. Is there no problems in video quality though by extending the VGA cable?
        I extended the cable by 5meters- pretty long. There was a quality loss on lilliput, but it looks very good on Xenarc- no loss. I think the difference may come from the ferrite-something the lilliput cable has and Xenarc has not.
        Again- no problems extending video cable on Xenarc.
        car computer status: ready_
        : epiam10000 256meg, audigy2nx :-F, ground loop :-)
        : check out my car putter here
        : check out my FrodoPlayer skin here
          Hey thanks. Last question is what kind of connector did you use to extend the USB cable? Aside from the VGA and sound port, that would be my only thing to extend.
          Thanks.
            I extended my Xenarc VGA with a 6' extender. I selected it based on price. Lowest price won. Works great, no apparent loss.
            I also extended the USB cable. It goes from the Xenarc USB to a hub, the hub connects via an 8' or so cable to the PC. The hub is non-powered and was also selected based on low price and the fact that it was tiny so I could bury it in my center console. Works great although I will advise that you should have operated the system in this configuration BEFORE installing it in the car.
            Reason is that Windows is picky about which port your devices are attached to. I found that the touchscreen worked fine in the house but when I added the hub it wanted to re-install and asked me to confirm that. Since I had no keyboard, I had no way to confirm. Plugging the keyboard/mouse into a port it had never been plugged in to brought the same query with no way to answer it! Morale of the story: set it up identical to the car before you put it in the car.
            Want to:
              I use a lilliput but the extensions are the same.. I used a cheap VGA extension, the VGA wire is not near anything that causes interference so tbh I've had no problems. Same with the USB... just a cheap cable!
              Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
              Car PC Status: Complete - Undergoing Software Redevelopment
                Yeah, my laptop is really picky about which hub goes into it which is why I just thought I'd go the extender route for now to just get the touchscreen working. Any suggestions on that as well as links? Also for the previous poster, which VGA extender did you go with?
                Thanks again.
                  Also wouldn't you need a male/female VGA connector. You said male/male. I dont think thats correct
                    male/female of course. The family type of a cable
                      I just went for a normal VGA extension cable. Male female. Is there any other VGA extension?
