I made a cheap nasty car PC - what you think
  • I made a cheap nasty car PC - what you think
    Its not done yet - and I had to use what I had on hand - no $$$
    I got a used Socket 370 Motherboard with P3 700mhz CPU
    20GB used hard disk and a old used ATX power suply
    and 128mb mem and stuffed it into a old black and white
    Security monitor CRT case - I got a old datalux Lmv10r 10
    inch LCD for $50 - it was dim so I replaced the miniature
    florescent light - mounted the datalux on a old cell phone
    mount arm - I have a power button in my cup holder
    the computer is in the back seat on the floor bord
    and its powerd by a inverter in the trunk - the inverter is
    turned off and on by a relay that also turns my amps of
    and on - lazzy - the bios is set to stay off if loss of power,
    and the computer only comes on when I push the on/off
    button - I disabled "Write Caching" in windows to keep
    from losing data if power loss and hard disk is mounted
    on its side - to help protect it -
    I use a mouse and joystick - and keyboard software
    so no need for a keyboard - and I hide the mouse and joy
    stick in my arm rest
    I even have GPS
    You can see my page at
    http://www.geocities.com/astro_van_1985/94olds.html
    Its a free web page so the bandwidth is low -
    I dont have lots of $$$$
    and I have lots of computer scrap
    All I had to spend money on was
    the inverter $35, LCD $50, Mouse $10,
    JoyStick $10 - every thing else I had
    I works well - but I need better software
    and the touch screen does not work - Yes I have
    read the fourns - and tried all the drivres - but
    I dont need it any way
    I want a good cheep or free GPS software - but
    just for speed, distance, heading, stuff like that
    I will pull over and use MS Streets and trips
    to find were I am at on a map - I have ADD
    real bad -
    I want to access OBD 1 data using my computer
    and see gauges or something - I have a Auto Xray
    but I want some thing easer and simple, on screen
    and needs to be cheep - real cheap
    My head unit Plays MP3s so thats not needed ,
    and the computer is more for when I have to sit and wait
    in my car - something to help not be bored - I could
    watch a movie or play a game - and I am a computer
    tech - so a extra computer computer might be good
    to have - load it up with windows drivers and and
    have a cd burner - ect ect
    I also want to set up a car alarm, and tint my windows
    - what car alarms are good and low cost ???
    I Attached some pics
    You are way ahead of the curve for new memebers. Welcome.
    TruckinMP3
    Read the FAQ!
      that true what he says about inverters? being more heat than electricity?
      [4Runna]
      next - wifi
        I not shure how mutch it loses as heat - but
        that why there is heat - a inverter is just like a amp - And running a
        amp or amps,computer, head lights, radio, inverter, AC, ect ect loads
        your alternator down a lot, any little bit to lessen that load helps
        I think I may need a new LCD mount - any cheap ones -
        I hit a bump and the lcd moved down and stayed there -
        and the wing nuts are way more than hand tight , I need
        to be able to move the LCD but it should stay were I put it
        - its a heavy LCD - I think 5 pounds - its like all metal
        I guess I can live with the thought that if I get in a
        car crach and the car is totaled the LCD will live on - LOL
        OR If I get car jacked I can rip it off its mount and beat
        them to death with it - what were they used in
        - Tanks ??? - HumVs - I herd Cop cars, but how could
        they see such a dim screen in the day
        I want to get a DC to DC ATX Power Supply - I am using a 300w inverter
        to power a 100w ATX Power Supply - I know its wastes a lot of power
        that way - How much is it wasting ???
        I need to rewire so that the computer can be turned on without
        the radio - for longer run times - with the car turned off
        - I know how to do - I am just lazy - I will wait till I get
        the DC to DC ATX Power Supply and just not use the relay
        I guess I need to limit the volts going to the Power Supply
        and keep them at 12v - so thats another $30 or more
        on top of the cost of the Power Supply unless I get the
        all in one unit for like $80 or more - I thought about
        that when using the Datalux LCD, So my ATX Power Supply
        powers the LCD
        Some day I will replace the Datalux with a Liliput
        and use the touch screen - replace my radio
        and use the computer for sound - but thats not for a
        long time
        And someday I will put linux on it -
        Every 2 or 3 months I will spend a $100 or so
        Any thoughts, Ideas stuff like that
          Energy cannot be created or destroyed.. and invertors aren't that efficient hence the heat is where the extra energy used goes. hence why the invertor cases are usually just big heatsinks.
          Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
          Car PC Status: Complete - Undergoing Software Redevelopment
            My Car PC has been in the works for over a year. I still haven't put the damn thing in. Running into issues with my TV out on my vid card not working with my monitor. Congrats on putting yours up.
            2006 Rav4 + iPod, still CarPCless
              energy can be created or destroyed, but thats getting technical....im a big physics geek :-P
              Current Progress:
              [▓▓▓▓▓▓▓---]80%
              Final Assembly
              Ramline P3 PC
              10.4 inch Touchscreen
              Windows XP Embedded
              Road Runner
              http://www.projektnepa.com
              Electrical Engineer / Mobile DJ
                Looks good, man.
                For the money you spent, that has to be the nicest system Ive seen.
                "Dont jack and drive"
                LOL!
                My first carPC!
                MP3/CD player
                Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
                Soon to actually find its way into the car!
                  Welcome, and great job!
                  肚子笑痛了
                  S60 Install
                    Nice one! Just watch the Pc doesnt get pinched.
                    As for the inverter, i think it might not use a full 300w if the load is only 100W. I suspect the load on the slave end of the transformer (i assume thats how they work - never looked in one) has an effect on the driving current - like alternators etc so it might not be complete overkill and by the time you aco**** for a saftey margin and inefficencies it aint too bad for now. the next step down (no pun intended) would be 150W which in my opinion is cutting it close with a 100W running off it.
                      I had a problem with my cell phone mount that I was using
                      for my lcd - I thought about how it was sitting, and the
                      way it was sitting, it was just about a inch lower than I need
                      - I would raise it up and drive - but I hit a bad spot in the road
                      and it would drop down a inch again - I looked in the house for
                      some thing to put under the LCD to keep it propped up
                      - yea I am lazy and cheap - I looked at wood - metal - and
                      plastic - I got the idea that a spray can cap, cut down to a inch
                      tall, would work well - LOL it does - when the LCD is setting
                      on it its at the right hight - I am still using the cell phone mount
                      but the spray cap keeps it from slipping down to far
                      On top of that, the cell phone mount allows the LCD to
                      face the under side of the dash - all you would see
                      from outside the car is that thick black cable running to the
                      monitor going under the dash - so I can hide the LCD
                      have a look
                        I may later set up a second monitor - use a sony PS1 LCD screen
                        in the back seat - My motherboard only has PCI slots so I will
                        get like a PCI Nvidia or ATI video card vith tv out
                        and just go with that, and its cheap
                        Thanks for all the Complements and praise every one !!!
                        When I get it more refined I will post in "Show off your project "
                        - I need to do a lot before then - but I think it looks ok now
                          You said you replace the flourecent lamp in the datalux...where did you get the replacement? what was it?
                          BossTone74
