help to fit internet access to car instalation
  • help to fit internet access to car instalation
    hi all
    fitted system into car all up and running but would like to surf the net aswell have a nokia 6600
    all help would be great as not a clue what to get or software to run
    cheers
    car- honda crv 2004
    carputer-installed
    screen-lillput
    40gb harddrive
    pryme nav-sat nav
    carnetix-1260
    Here ya go
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      just reading throght that link which do i need to connect to my mobile/cell phone either a bluetooth dongle or a 802.11g or 802.11b dongle??
      help!!!!!!!
      car- honda crv 2004
      carputer-installed
      screen-lillput
      40gb harddrive
      pryme nav-sat nav
      carnetix-1260
        I use BT to my 6620 and it works great. You need some sort of data service for the phone and the Nokia software on the PC.
          what do you mean by data service?
          cheers
          car- honda crv 2004
          carputer-installed
          screen-lillput
          40gb harddrive
          pryme nav-sat nav
          carnetix-1260
            cheers
            You need GPRS on your phone, you have to pay for it from your service provider. (T-Mobile, Sprint, Cingular, etc).
            Dak TruckPuter:
            Mac: - Researching and Awaiting Funds
            Changed to planning for a Mac Mini Trukputer...w3rd.
              phone has been enabled for gprs
              car- honda crv 2004
              carputer-installed
              screen-lillput
              40gb harddrive
              pryme nav-sat nav
              carnetix-1260
                Your phone needs bluetooth and your computer needs bluetooth to connect that way. The 802.11 stuff you're talking about is WIFI, different from GRPS. If you don't have bluetooth on your phone then you will need a Serial/USB data cable to interface the phone with your computer.
                Dak TruckPuter:
                  get ready to pay, depending on the carrier it can get real expensive real quick... Cingular just gave up there good plan... for unlimited surfing it is $80/month...
                  g1smo...as far as bluetooth vs 802.11... I think you missed the way it works... bluetooth to phone is option#1... 80211 is option#2... totally separate, you can have one or the other OR both, but they have no connection between them...
                  next time you have a question, try to post all the important information... like what cell phone company, what you are looking for (download music/files or just weather info), it would be nice to know what country you are in.. based on your wording and typing it seems that you are not in UK or USA... so things will be different based on these pieces of info...
                  EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
                    sorry m8 im in the uk on orange network got my nokia 6600 connected via bluetooth but cann;t see the modem option. and how to connect it
                    car- honda crv 2004
                    carputer-installed
                    screen-lillput
                    40gb harddrive
                    pryme nav-sat nav
                    carnetix-1260
                      Again more specs, PC, Mac, Linux? Which versions of the operating system? You need to provide full details for us to be able to help you.
                      Dak TruckPuter:
                        There are 2 options to connect to the internet wirelessly using your carPC (or home PC).
                        Option 1: 802.11 WiFi, you can connect to it if you are within range and the Access point (AP) is open for you to use. There maybe some legal isssues here regarding to unauthorize connect to some one network, but that is a different thing. With this option, all you need is an 802.11 WiFi adapter (PCI, USB, PCMCIA).
                        Option 2: Using your cell phone carrier as data provider. If your cell phone carrier provide/has GPRS and your phone is capable of. You have to pay your cell service provider/carrier for them to turn the option on for you to use. With this option, you have to buy for the service (just like DSL), phone capability , connection between cell phone and PC (Bluetooth, data cable, ... IrDA). Technically this is broad band internet for cellular phone and called GPRS and your cell phone a broad band modem. DSL is broad band internet for home/land line phone.
                          pc mini-itx via m10000 running xp pro
                          car- honda crv 2004
                          carputer-installed
                          screen-lillput
                          40gb harddrive
                          pryme nav-sat nav
                          carnetix-1260
                            Hi there,
                            You might want to check up on Nokia's web site for the drivers to enable the 6600 (a.k.a Fatboy) to act as a modem. The link is as follows:-
                            http://www.nokia.com/nokia/0,8764,42290,00.html
                            Once you've got the driver, you should be able to connect using the Fatboy. If you can't theres a few forums on the net that I seriously recommend for you to have a look at:-
                            www.allaboutsymbian.com
                            www.i-symbian.com
                            These 2 sites are Symbian centric and contain a wealth on information on the Symbian OS thats running on the 6600 and other Symbian Series 60, 80 and 90 phones.
                            A specific thread on getting GPRS to work on the 6600 with the Cingular network is located here :-
                            http://www.mobiledia.com/forum/topic16201-0-asc-10.html
                            Hope this helps. By the way, Symbian ROCKS!!
                            Malaysia
                            -Alfa Romeo Giulietta 1982 with 1992 Alfa 75 2.0 Twin Spark Engine-
