Lilliput TouchScreen hookup problems
  • Lilliput TouchScreen hookup problems
    Hey everyone..I've been trying to hook up my Lilliput 7" touchscreen to my mini pc, but after installing all the drivers and hooking up all the cables(I believe correctly), still nothing but "no VGA signal"... can anyone help, I've exhausted myself trying all the different possibilities... Thanks in advance!
    BTW, I'm connecting everything using the power from the wall, untill everything is running right and then everything is going into the car. Also, i know the PC is running right because I'm able to run it on a normal monitor.
    Thanks again!
    You probably have the wrong resolution it needs to be 800x600
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Netgear WG121 USB WiFi
    Carnetix P1260
      tried it..and still the "no VGA signal"..
        Please help...
          1. Don't cross-post. It will only annoy people.
          2. Don't expect an answer in just 2 hours. Sometimes you get one quickly, sometimes it takes some time.
          3. What type of motherboard are you using? When you say you've tried "everything", what does that consist of? Have you tried using a computer that you know has good output?
          Have you read the FAQ in the LCD section that says "Everything you've ever wanted to know about your Lilliput?"
          Want to:
            Motherboard:VIA CLE266 + VT8235 Chipset Motherboard
            As far as what I've done.:
            -Connected VGA cables
            -Lowered Resolution and Color Quality to the loweswt possible.
            -Enabled VGA
            -Set to LCD (as states in FAQ of Lilliput)
            The computer I'm using works fine on a CRT, but when it comes to the Lilliput , it's a different story.All I get is a blank screen and sometimes it pops up a "No VGA signal".
            & yes, i have tried everything I found that would relate to this issue in the FAQ as well..
            Any help is appreciated and sorry if I annoyed anyone...just trying to bring the topic to a more specific forum..
            Thanks!
              Have you tried the Lilliput on a working computer besides the Via?
              Want to:
                Have you done any modding to the lilli or is it still in the original out-of-the-box form?
                A car without turbo is a car with perpetual lag.
                My Ride
                My New Page
                  No, I guess I should,... but it's because I've been thinking I'm not connecting or enabling something, but I could be wrong
                  Yes I have modded it... This project was orignally started by a buddy of mine that molded the screen, but prior to molding he did check that the screen was functioning. The only thing is that he wasn't able to finish it before he moved out of the country, so now I've taken it over. I've put everything back together exactly how it should be and the screen is working...Since I'm seeing the "no signal" screens.
                    ttt
                      Well, there might be something wrong with the vga in on the lilli while still having functional power. That would be my first idea. Try it on a computer that you know has a functional vga and let us know what happens.
                      My Ride
                      My New Page
                        might help
                        I'm a newbie, but had the same problem. Long story short I set my bios settings to lcd, my res. to 800x600. My screen came up no vga signal.
                        So I took my computer back into the house and could'nt get a pic on my lcd monitor in my house either, considering that I had just put some new programs in from my house 10 mins ago, I figured it had to be the new setting(lcd) but now I could'nt even get a pic to change my settings. So I had to reset my cmos. This worked I got pic back on my house lcd. Then I went back outside and it also worked on my lilliput. Like I said I'm a newbie and more of a try things till it works type of guy, but I thought I could possibly help. Good luck!!!
