Getting a Wire from Battery to Amp
  • Getting a Wire from Battery to Amp
    Just riped my car apart and cant find anyway to get the power cable from the battery to the amp, there apears to be no holes which i can run the power cable from the battery to inside the car!
    Is there any tricks or anythink im missing, please help
    Car is a Zafira GSI
    Car is a Zafira GSI
    Vauxhall Zafira?
    Might be best asking on vauxhall forum, in the ICE section as you have a chance of someone having the same car.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
      Most cars have grommets in the firewall that you can pop out to run wires through, if not you can always just drill a hole. Just remember to seal it up so it doesn't start to rust.
      Visit my website at:
      http://www.hostilejava.com
      http://hostilejava.com/gerbil5.jpg
        Thanks for the replys, in the end i had to use the 12v 150w extra lighter socket in the back which seems to be working ok.
        On a side note though where are the vauxhall ice forums? I looked on vauxhall.co.uk but there doesnt seem to be any forums.
          I just drilled a new hole in the Pug - all the other cables were too tight to fit anything else through
            you did proberly the easiest thing, another way is to run from any other 12v power supply.. depending how many devices are on that fuse/chain. eg. headunit normally connected with door light.
              wow, how powerfull is the amp? 150 watts wouldnt cut it for most people
              PC Components:
              My work log
                I was thinking that myself but figured some people have to learn the hard way. Hey maybe it's a low current amp design.
                  Its a Calibar 800w amp, its only temp but so far it seems to be working grate, i added a extra fuse between the amp the lighter socket just in case though.
                    Any amp should be powered direct from the battery. There MUST be a hole in the firewall, just look very carefull for it. I found mine pretty hard, but I can assure you it's there. Try and search behind the wipers main block, or something that's where mine was. You will find it. Remeber, you MUST power it from the battery!!!
                    Renault Megane...the OEM look
                      I got 4 Gauge wire running through my firewall. There is a hole big enough i'm sure in your car. Try looking where the steering wires run through the firewall. That's the best place to start. Anything you need for installing a amp and routing wires can be found here http://www.crutchfieldadvisor.com/S-...de.html?page=1
                      Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
                      My 2000 Saturn SL2 Worklog
                        or run teh power wire under the car with the brake lines or the rear washer pipe.
                        just make sure its shielded
                        Still Planning and Scavenging Parts ------Software-----and anything else i can lay my hands on!!! :)
                        Acquired a Toshiba Satelite 4000CDT
                        HDD`s ****ed new one on way! 30gb Toshiba.
                          I have had good luck following the hood release cable on newer cars.
                          Fabricator
                            wow - that's absolutely scary
                            I don't know of anyone who installs car audio that would recomend running the power for the amplifier off of such a small current source...
                            that's pretty scarry
                            that 800 watt amp is probably more like 400 watts, which is still too much of a pull IMO
                            you need to take a look at the size of the fuse that's on that lighter source...
                            if it's 60 amps and below - 8 gua is fine
                            if it's above 60 amps you need 4 guage
                            I would honnestly just go back and spend some time looking at your fire wall...remove the carpet, pull it back, and take a flash light under your dash with you. Look for a small open area and get a good idea of where it is at, then look under the hood and see if you can tell where that clear space is on the other side of the firewall...take a unibit and start to drill away - you would be wise to have someone standing outside of the car looking down into the engine compartment to watch your drill bit and make sure you don't hit anything vital
                            I would get out there and do that ASAP.
                            Jan Bennett
                              I spent ages looking for holes but there was none to find and i didnt want to drill holes cause of the warrenty, i will try post some pics but cause the zafira have such a small ffront everythink is mega packed together all the wires which go into the car are all done via connecters no strait through cables.
                              Also another question as im new to all this, i would like to add a extra battery in the back to power all the stuff i want to add how to i go about doing that?
